Author Topic: Uneven idle speed  (Read 1076 times)
Hannah Judes Dad
    • the misses round the bend
Uneven idle speed
« on: 02 November 2009, 21:54:56 »
Is there anything that can be done to cure the uneven idle speed on my mig? it hovers around 500 rpm then rythmicaly drops to 350-400 then back to 500 again.It is a continual cycle of 500 500 500 500 350-400 500 500 500 500 and so on
« Last Edit: 02 November 2009, 21:55:43 by hannahjudesdad »
Re: Uneven idle speed
« Reply #1 on: 02 November 2009, 21:56:50 »
clean the idle control valve, and check for any air leaks.
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
« Reply #2 on: 02 November 2009, 22:20:11 »
would say manifold is lose. but def an air problem.
« Reply #3 on: 03 November 2009, 09:00:25 »
ehhh? Main symptons from a leaking manifold would be ticking, as well as really loud!
As they have only mentioned idle, most likly ICV/air leak.
« Last Edit: 03 November 2009, 09:00:35 by tunnie »
Hannah Judes Dad
« Reply #4 on: 03 November 2009, 09:27:34 »
I'm waiting for the rain to stop and then I will have a look at the valve.Thanks guys
« Last Edit: 03 November 2009, 09:27:53 by hannahjudesdad »
