Pages: 1 [2] 3  All   Go Down
Author Topic: Oil sump plug stripped thread - what are my option  (Read 4595 times)
Welung666
Re: Oil sump plug stripped thread - what are my option
« Reply #15 on: 15 September 2009, 21:03:14 »
But is it the sump that's stripped or the plug?
« Reply #16 on: 15 September 2009, 21:34:24 »
It will be the sump stripped, they are alloy on the tractor.
The kit I have only requires a replacement sump plug because its actualy for spark plugs....I dont have the correct size helicoil kit for the standard sump plug. But thats irrelivant as I have a sump plug that will fit the helicoil.
Welung666
« Reply #17 on: 15 September 2009, 21:36:52 »
Ah, didn't realise it was a tractor  ::)
osealy
  • dublin
« Reply #18 on: 15 September 2009, 22:29:03 »
My option was the cheap easy option. If someone will helicoil it for free, sump on, go for that.
Most boats engines pump sump oil out and do interstellar milage.
The car is worth 5-15hundred so why spend a lot when a little will make life easier!!!!
« Reply #19 on: 16 September 2009, 07:50:33 »
ahhh the old plastacine tractor sump  ;D
« Reply #20 on: 16 September 2009, 09:21:02 »
I would be taking the MDTM option ;)
Christopher doc
  • Dartmouth
« Reply #21 on: 16 September 2009, 10:54:26 »
Thanks guys for all the suggestions. I am going to go with the helicoil option and get a Pela pump so I don't have to drain the b#####r again.
« Reply #22 on: 16 September 2009, 11:00:19 »
pumping oil out is gonna leave a lot of sludge behind  :-/
I wouldnt.
imho - Helicoil, and drain as normal  :y
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #23 on: 16 September 2009, 15:49:01 »
Definitely!
« Reply #24 on: 01 November 2009, 20:18:03 »
Could do with getting the helicoil kit back please.....and the wrench for the tap
« Reply #25 on: 01 November 2009, 20:20:45 »
I am open to all suggestions ...... !!
I replaced the lower sump pan on mine with a new one from vauxhall. It wasn't expensive IIRC it was less than £60 for thesump pan, sealant/gasket & oil. Bolton council paid for mine!  ;)   ;)
« Reply #26 on: 01 November 2009, 20:55:52 »
You would not want to do that on a TD, not so easy!
Note, this post was answered in mid September its just I have not had my loaned out tools back  :'(
« Reply #27 on: 01 November 2009, 20:59:59 »
Ah!! I think I must've thought I was replying to Jame's welded up sump plug thread!!  ;D  ;D  ;D  ;D
« Last Edit: 01 November 2009, 21:00:15 by Andy_B »
« Reply #28 on: 02 November 2009, 18:02:32 »
If members are slow to return loaned tools, this will most likely reduce the chances of the loaning member being so willing to loan again  :'(
« Reply #29 on: 02 November 2009, 19:01:52 »
I concur  ;)  ;)
Pages: 1 [2] 3  All   Go Up
Page created in 0.035 seconds with 20 queries.
