Author Topic: Delayed Reaction  (Read 3483 times)
golly
Delayed Reaction
« on: 02 November 2009, 20:26:04 »
My car seems to have a delayed reaction/very slight shudder when pulling off from a standing start,and if i accellarate hard it feels as if the gearbox suddenly drops into gear.Any ideas ? (3.0l Auto)
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: Delayed Reaction
« Reply #1 on: 02 November 2009, 20:51:02 »
it could be oil in the clutch hosing would clean out with the hosepipe, flush all muck out and see i that helps. could be somthing els but i do mine ev now and then, dont use a pressure washer as that will remove the grease on the thrust bearing. y:
« Last Edit: 02 November 2009, 20:52:07 by Russell_Hill »
Stevie-blunder
  • Wolverhampton
« Reply #2 on: 02 November 2009, 21:42:46 »
ATF needs topping up, just had very similar with mine, topped up... sorted. Look for leaks though.  :y
alank46
  • South Devon
    • 3L Elite Estate 1996
« Reply #3 on: 02 November 2009, 22:50:49 »
Hi
The OP did say that it was an automatic!
Alan
rustym95
« Reply #4 on: 02 November 2009, 23:16:41 »
and? clutch is a clutch. would check the engine rev sensor for the auto box.
« Last Edit: 02 November 2009, 23:20:44 by Russell_Hill »
« Reply #5 on: 02 November 2009, 23:30:29 »
and? clutch is a clutch. ......
A Manual clutch/pressure plate/flywheel is nothing like a 'proper' auto.
« Reply #6 on: 02 November 2009, 23:39:15 »
 :o :o :o :o ;D ;D ;D
As said before - check atf level in autobox and top up.
« Last Edit: 02 November 2009, 23:39:38 by dbug »
rustym95
« Reply #7 on: 03 November 2009, 01:30:26 »
but the clutch is the same, was not meaning presure plate etc just the clutch pads, muck and stuff still get in there and needs to be clean'd out somtimes, oil and road muck can cause clutch spin.
« Reply #8 on: 03 November 2009, 01:32:25 »
No its not - autoboxes do not have a clutch!!  Power transmitted thro a torque convertor!!
rustym95
« Reply #9 on: 03 November 2009, 01:35:33 »
well the one i have in garage has a clutch on it, and thats off a 2000 2.5.
« Reply #10 on: 03 November 2009, 01:40:28 »
Then its not an autobox - an autobox does NOT have a clutch - it has a torque convertor.  No autoboxes use a clutch as used by a manual box.  Be told  ;)
rustym95
« Reply #11 on: 03 November 2009, 01:51:30 »
well you keep thinking that, ive seen it the bloke that sold it to m8 seen it, sports box auto 10inch clutch hydrolic piston, air vent cooler off a saloon.
« Reply #12 on: 03 November 2009, 01:59:41 »
Repeat an autobox does NOT have a clutch - it has a torque convertor.  Flogging a dead horse springs to mind  :-? :-?
rustym95
« Reply #13 on: 03 November 2009, 02:07:31 »
you can flog a dead hose. why do you have one. [smiley=bath.gif]
« Reply #14 on: 03 November 2009, 09:56:27 »
Agreed. Only clutch you'll find in an automatic gearbox will be small internal ones for changing the ratios. it is of course the torque converter that sits in the bellhousing, where a clutch would be on a manual box, and controls transmission of drive from  engine to transmission.
