Author Topic: Remote locking problem?  (Read 1084 times)
blackviper90210
  • Bromsgrove, West Midlands
    • 03 3.2 Elite Saloon
« on: 01 November 2009, 19:21:45 »
Evening all!
Last few days when I use the fob to lock the car, the car locks but then unlocks straight away.
If I use the key everything locks fine, then using the fob to unlock, the drivers door stays locked.
Obviously the drivers door is the problem, any ideas what is causing it?
Its a facelift elite saloon.
Thanks for your help!  :)
AKA - Mr Bracket
Re: Remote locking problem?
« Reply #1 on: 01 November 2009, 19:27:18 »
Dodgy driver's door locking motor. You can sometime prolong the agony by lub'ing the various rods between the lock & handle etc, but it does sound like you need to be looking for a replacement lock motor!  :y  :y  :y
blackviper90210
« Reply #2 on: 01 November 2009, 19:56:29 »
Thanks Andy, will strip the door apart this week and lube it like no tomorrow!!
Cheers. ;D
AKA - Mr Bracket
Hovelite
  • Sussex Coast
  • always look on the bright side of life!
« Reply #3 on: 03 November 2009, 23:43:09 »
Mine won't pop up on the drivers door every time (though often does).  All others seem to work OK.  Is this a lube fix too?
She passed the MOT!
Pete Elite
  • Uxbridge, Middlesex
« Reply #4 on: 04 November 2009, 01:23:33 »
My D/S rear door lock doesn't go done with the first click but does with the second, what causes this :question.
