Author Topic: ABS & TC Lights Stays on Occasionally  (Read 1633 times)
SnakePliskin
  • Anglesey
  • OMEGA MV6 Estate Manual Owner
« on: 01 November 2009, 18:36:18 »
Hello one and all
I promise once ive got MOT on my steed i shall leave you all alone with regards to problem solving lol
My pride and joy is awaiting an MOT retest once the brake lines and handbrake cable is replaced this week but i currently have one last problem to overturn
My ABS & TC Light is intermittant. It turns off once the vehicle is started and the speedo works fine as it should. Then another time she starts and the lights stay on and the speedo doesnt work
Have you got any ideas what this could be?
« Last Edit: 01 November 2009, 18:37:59 by SnakePliskin »
Love VX's always Have
I_want_an_Omega
Re: ABS & TC Lights Stays on Occasionally
« Reply #1 on: 01 November 2009, 18:44:46 »
Early symptoms of ABC/TC ecu failure there mate .........  :(
SnakePliskin
  • Anglesey
« Reply #2 on: 01 November 2009, 18:50:37 »
Are they easy enough to replace?
I_want_an_Omega
« Reply #3 on: 01 November 2009, 19:49:05 »
hI've not done one but I'm sure there is a how to in the maint section - & I know that plenty of people have done it. You can get them refurbed as well.
« Last Edit: 01 November 2009, 19:50:02 by I_want_an_Omega »
« Reply #4 on: 01 November 2009, 19:53:17 »
Access to the ECU is a bit tight but its doable :y
« Reply #5 on: 01 November 2009, 19:53:19 »
I done mine, not too bad of a job  :y
« Reply #6 on: 01 November 2009, 22:13:28 »
Deffo abs ecu on way out mate.  Fiddly job to swap - just need patience!!
SnakePliskin
  • Anglesey
« Reply #7 on: 02 November 2009, 00:42:35 »
Where is it located?
« Reply #8 on: 02 November 2009, 01:52:12 »
Passenger side of engine just below power steering resevoir :y
SnakePliskin
  • Anglesey
« Reply #9 on: 04 November 2009, 00:21:01 »
If i get one with the same ecu  number will this be a 3 litre one?
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
« Reply #10 on: 04 November 2009, 00:23:59 »
i think it needs to know if its running a manual or auto though. you really need like for like tbh.
SnakePliskin
  • Anglesey
« Reply #11 on: 04 November 2009, 00:35:40 »
Right okay
Shall get on it then!!
Ive got a replacement one here but havent checked the codes. Will have to see tomorrow. If i havent got one that matches ive got a garage up the road that has Tech 2. Can they reset the ECU?
« Reply #12 on: 04 November 2009, 08:31:22 »
If for exactly same year/model Tech2 not needed (includes same gearbox), otherwise Tech2 session may be required.
Page created in 0.021 seconds with 16 queries.
