Author Topic: new doors fitting  (Read 1443 times)
trainastock
  • st neots  cambridgeshire
new doors fitting
« on: 04 November 2009, 08:32:16 »
hi
have a chance to replace my 2 passenger doors from same  colour same spec car ,how easy is it to change them , just the electrics i am concerned about i presume that the doors just bolt on ????
                     cheers  :y :y
Re: new doors fitting
« Reply #1 on: 04 November 2009, 09:07:40 »
 i presume that the doors just bolt on ???? ......
They're held on by the roll pin hinge. You need to pull each pin out, top pin down & bottom pin up with a suitable pin remover. I've never done the electrics bit would would assume that the plugs will be the same throughout.
And the door stay needs unbolting, assuming it's not already been pulled through.  :y
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #2 on: 04 November 2009, 09:14:57 »
Exactly as Andy says, but I use a small pair of mole grips to grip onto the role peg then gently Smash the mole grips ;D
Both pegs knockout towards each other, the top one down, the bottom one up :y
« Reply #3 on: 04 November 2009, 09:18:54 »
This is what I made to remove a couple of pins.
trainastock
« Reply #4 on: 04 November 2009, 09:49:04 »
excellent  thanks for that hopefully looks straight forward
 thanks :y
