Author Topic: Cold Air behind Radio.  (Read 3539 times)
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« on: 01 November 2009, 19:31:10 »
Is it normal to have cold air blowing behind the Radio?, even though the heaters on.
Facelift ex plod with a big hole where the radio should be.
Re: Cold Air behind Radio.
« Reply #1 on: 01 November 2009, 20:09:04 »
Quite often they remove the plastic duct that runs from below the radio and down past the handbrake.....could be this.
zirk
  • Epping Forest
« Reply #2 on: 01 November 2009, 22:13:29 »
Thanks again Mark, will have a look tomorrow in the daylight.. :y
« Reply #3 on: 01 November 2009, 22:19:33 »
Will be as Mark says, has the same on mine also the reason rear vents don't work  :y
Boracic
  • Dartford Kent
« Reply #4 on: 01 November 2009, 22:41:27 »
I have a small hose behind the radio blowing cold air, about 19mm in diameter
Pete Elite
  • Uxbridge, Middlesex
« Reply #5 on: 02 November 2009, 00:42:32 »
 That's probably the one that connects to the back of the Glovebox for the chiller :).
zirk
  • Epping Forest
« Reply #6 on: 02 November 2009, 01:25:32 »
Glove box, chiller, rear heater, Im confused now!
Boracic
  • Dartford Kent
« Reply #7 on: 02 November 2009, 02:03:42 »
Nope, I was told it was for radio cooling, all my hoses are in the correct place and the glove box cooler is connected
Pete Elite
« Reply #8 on: 02 November 2009, 02:05:04 »
 Don't worry about it Zirk, just put a overcoat on and forget about it ;D.
Boracic
  • Dartford Kent
« Reply #9 on: 02 November 2009, 02:10:55 »
lol, and the stereo will always be cool
Pete Elite
« Reply #10 on: 02 November 2009, 02:16:30 »
  I've not heard of a Radio cooler before :-?.
zirk
  • Epping Forest
« Reply #11 on: 02 November 2009, 03:03:51 »
well all I know is it blows cold there depite what tempreture the heater is on. :-/
zirk
  • Epping Forest
« Reply #12 on: 04 November 2009, 11:30:37 »
Some pics of where the cold air is comming (blowing) from, the rubber pipe pointing directly at the back of where the radio should be. should it be connected to something else?. Any thoughts.
Pic 2, no warm/ cold air arround for the rear passingers, but its been well messed with by the Met.
mathewst
  • Split, Croatia
    • v40
« Reply #13 on: 04 November 2009, 11:41:30 »
Well at least you'll alwys have cool music coming from the stereo ;D
zirk
  • Epping Forest
« Reply #14 on: 04 November 2009, 11:50:05 »
Yea if I had a stereo, brings a new meaning to piped music.  :y
