Author Topic: removing td starter motor  (Read 1495 times)
raywilb
  • york. moved to Dalton , Thirsk
    • Citroen C4 Cactus
« on: 05 November 2009, 12:01:37 »
i cannot get to the top bolt on the starter motor..  does the inlet manifold have to come off to gain access i,m stuck at the minute. :-/ :-/
Re: removing td starter motor
« Reply #1 on: 05 November 2009, 12:11:35 »
I removed the inlet manifold and it was so much easier to get at the starter motor, only problem is you might need new paper gaskets for the manifold as mine ripped.
raywilb
    • Citroen C4 Cactus
« Reply #2 on: 05 November 2009, 13:36:33 »
thanks for that i thought after a hours attempt it was the way ahead. i,ll get new gaskets as they wasn,t changed when glow-plugs were done. :y :y :y
alexh551
  • bardney, lincolnshire.
« Reply #4 on: 05 November 2009, 19:01:38 »
if you have a cut down 19mm spanner and are able to get the car up in the air it can all be done without taking inlet off.
Omegatoy
  • UK
« Reply #5 on: 05 November 2009, 19:15:50 »
done both mine from underneath, bit of a fiddle to get the bolt baclk in but no messing with the inlet!!!! :y
raywilb
    • Citroen C4 Cactus
« Reply #6 on: 05 November 2009, 21:01:01 »
i had it well up in the air and i struggled. mot booked for tomorrow. so next attempt is with manifold off, cheers guys  :y :y
« Reply #7 on: 06 November 2009, 10:06:18 »
Easier to take manifold off than mess about from underneath
