Author Topic: Self leveling shocks?  (Read 3755 times)
Omega Pixie
  • Yorkshire
« on: 01 February 2008, 09:15:30 »
How do i conferm that my shocks are not self leveling.
Matchless
  • Nottingham
    • A white van
Re: Self leveling shocks?
« Reply #1 on: 01 February 2008, 09:22:28 »
Look at the shocks, if there is a thin plastic air pipe connecting near the top then they are self-levelling.
hotel21
  • The Kingdom of Fife
« Reply #2 on: 01 February 2008, 09:22:59 »
Have a look at them.
Believe that self levelling will have an air pipe fitted to the shocks.  Also, there is a level sensor on the rear drivers side suspension arm, similar to those on the rear passenger and front passenger lower arms if the car is fitted with factory HID's.
Markjay
  • London
« Reply #3 on: 01 February 2008, 16:56:38 »
Rear shocks only, obviously....
Alas, no more Omegas....
mkaminski100
  • Basingstoke
« Reply #4 on: 21 February 2009, 19:10:33 »
What if the shock absorber is leaking? I think I just found a leak - oil is coming from underneath the rubber . I think I've seen some photos of dismantled absorber but cant find it.
« Reply #5 on: 21 February 2009, 19:27:37 »
...... oil is coming from underneath the rubber  ......
Then they're 'rubber ducked' I'm afraid Marcin!    :(
« Reply #6 on: 21 February 2009, 20:04:03 »
If you want to confirm whats fitted, you can see the air pipe R clipped to the shock body visible above the wheel.
If you want to check the sl is working open the boot, turn the ignition/ engine on and sit on the bumper/boot ledge with you feet on the floor. When the pump kicks in you'll feel the back end rise to compensate for your extra waite.
But if they are leaking oil thats nowt to do with sl. Your damper oil is leaking out and as with any shock, they are breaked. No damping, the back end will hop bounce and bang over bumps. Its exactly what happened to mine. Go steady in the corners untill you get it sorted, you stand a good chance of loosing the back end.
150 a pair from vx on tc.... Ffs!
Still got my old ones with a view to taking them apart and see whats wrong with em, but first glance does not look hopefull. One day... :-)
mkaminski100
  • Basingstoke
« Reply #7 on: 21 February 2009, 20:06:25 »
Thanks Andy & Chris. I must say, I don't know how this system works. I mean is it a normal shock absorber with extra space to add some air, or ca it be dismantled and parts can be replaced?
It looks like there is a leak between bottom tube and a rubber and I think I've seen photos on OOF with dismantled NIVO.
The bottom line is whether I can fix it or do I have to buy a replacement (over my car budged as I have already spent almost £200)?
« Last Edit: 21 February 2009, 20:15:47 by mkaminski100 »
« Reply #8 on: 21 February 2009, 20:22:27 »
Yes!  :y
..... or ca it be dismantled and parts can be replaced? ....
Afraid not, new shockers needed.  :'(
mkaminski100
  • Basingstoke
« Reply #9 on: 21 February 2009, 20:38:36 »
More toys, more problems... I have already paid £150 for fluids and cambelt kit, today I have rounded auto box plug, so will have to replace oil, filter and gaskets instead of topping up (extra £80-90) and now this.
Is it worth to go for a second hand one or new set is required?
« Reply #10 on: 21 February 2009, 20:44:42 »
Estate with self-levelling suspension 72119085 £107.00 £90.98 £67.46
£135+vat for the pair on Trade Club. You could probably find plenty of other things to spend that amount of money on though.  :-?
« Reply #11 on: 21 February 2009, 20:50:43 »
or just fit standard shocks, 50 sobs i think. And pull the fuse for self levelling?
mkaminski100
  • Basingstoke
« Reply #12 on: 21 February 2009, 21:04:39 »
I will have to think about it. Nivo is pretty rare on scap yards, dont know if it's worth to get a second hand ones or just get a new set.
Second option reminds me about my old Omega - another £30, another £40, another £15 and I ended up spending around £1000 on this car because there always something to be fixed....  >:(
I also consider replacing these with standard ones as I cant see the difference (apart from the stiffness of 17" alloys) but I already paid for this comfort ;) At least I didn't pay a lot for this car.
I think that I will do all engine maintenance (oil leaks, spark plugs, cambelt, fluids etc) and find how it behaves (extra failures, petrol consumption etc). If it deserves to be maintained properly and will not disappoint me in a big way, I will make her happy with new dampers :)
« Last Edit: 21 February 2009, 21:10:42 by mkaminski100 »
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #13 on: 21 February 2009, 23:20:43 »
Yep!
remraf
  • Leicestershire
« Reply #14 on: 11 October 2009, 21:20:01 »
I'm pretty sure that my 1999 3.0 Elite estate has the SL shox on having had a grovel around under the car and can see a pipe and a sensor thing on the rear arm.  We use the car to toe a caravan who's jockey wheel has been getting lower and lower over the last 12 months so guess the shox have had it (10 year old shox I guess). Have checked the fuse box panel and see also that there is a 20 amp fuse in slot 27, so presume this confirms it, but was wondering where the pump is to pump the shox up and wonder if anyone knows if you can tell if this is working correctly? Lastly, where best to get these items from?  Thanks to anyone with the answers!
