Author Topic: head light range sensor  (Read 1654 times)
SP_3.2
  • Leicester
    • drives A6 allroad 3.0tdi
« on: 07 November 2009, 10:28:53 »
Could anyone tell me where the headlight range sensor is and the conector for it is . Was thinking it was on one of the wishbones may need to check the conection on it.
Thanks
Steve
Welung666
Re: head light range sensor
« Reply #1 on: 07 November 2009, 10:36:26 »
For the self-levelling there are 2... Both nearside front and rear wishbones :y
« Reply #2 on: 07 November 2009, 10:36:49 »
Front N/S by wishbone and rear N/S on trailing arm
SP_3.2
  • Leicester
« Reply #3 on: 07 November 2009, 11:02:44 »
Thanks will give them a clean :y
pscocoa
  • Sandhurst Berkshire
    • Volvo V90 D5 & Grandland
« Reply #4 on: 07 November 2009, 11:21:35 »
Thanks
Steve
Does your range warning light come on randomly?
SP_3.2
  • Leicester
« Reply #5 on: 07 November 2009, 11:25:31 »
Just 1st thing on the morr on start up . Has only happed in the past few weeks with the cold nights. was thinking of just giving the conectors a check over.
pscocoa
« Reply #6 on: 07 November 2009, 20:01:56 »
Interesting development on my 3.2
I have for say 4 years had an issue with the Headlamp Range Warning Light - the motors and level are conifrmed all working - and has been checked several times. I now just ignore it - the problem can last for a day or a couple of days and then disappear or confine itself to start up - irrespective of weather conditions.
2 days ago for another reason disconnected wiring loom from rear parking sensors - so far no head lamp range warning light at all and yet earlier in the week had been flashing up. Will keep under observation
« Reply #7 on: 07 November 2009, 21:01:23 »
pic here of the front...similar on rear, look in between door and wheel :y
http://www.omegaowners.com/forum/YaBB.pl?num=1219190177
SP_3.2
  • Leicester
« Reply #8 on: 08 November 2009, 12:34:39 »
Thanks Chris.  :y
« Reply #9 on: 09 November 2009, 11:08:11 »
I have for say 4 years had an issue with the Headlamp Range Warning Light....
Can you make it to the Camberley meet this weekend? If so, we can put the tech 2 on it and compare the readings with other cars. I have an odd issue with mine. No warnings but it spuriously raises the beam, much to the annoyance of oncoming traffic. :-[
pscocoa
« Reply #10 on: 09 November 2009, 13:52:28 »
Thanks Kevin - unfortunately I am in Cambridge and Manchester from Friday morning through to Sunday evening so will not be at the meet.
Still no reappearance of headlight range warning light whilst parking sensors are still disconnected.
