Author Topic: 200m from home with a stuck wheel nut in Runcorn  (Read 1795 times)
zirax
« on: 09 November 2009, 21:19:41 »
Evening all. I am rather stuck at the moment. The garage back home has jammed a locking wheel nut on with their gun. Tried budging the nut by hand and it's having none of it! I don't really have the right tools for the job up here in Runcorn as I work away during the week and the real tools are down in Chelmsford ~200miles.
Does anyone know a good garage in the area that I could get them to crack off the nut and fit a tyre I have in the boot? Granted any garage could potentially do it but I'd rather not end up at a cowboy outfit. The tyre on there is ok but low, so much for an easy job during the week  :'(
Or if someone has a proper breaker bar in the area and wouldn't mind giving me a hand, that would be awesome. I have normal nuts to go back in as a stopgap and can get the tyre guy back round. Beer tokens on offer :)
Dr Richard Stephens:- "I would advise people, if they hurt themselves, to swear."
Re: 200m from home with a stuck wheel nut in Runcorn
« Reply #1 on: 09 November 2009, 21:23:46 »
do you have the standard GM jack wrench with you? If so use that, then find some leverage. I used the GM wrench + handle from a standard jack to give extra power....
« Last Edit: 09 November 2009, 21:24:14 by tunnie »
« Reply #2 on: 09 November 2009, 21:32:49 »
I've snapped too many of those crppy things :o
« Reply #3 on: 09 November 2009, 21:43:10 »
Aye, they not great, they make pre-facelift MV6 alloy look like titanium, but he's up poo creak at the mo so worth a punt i guess?
zirax
« Reply #4 on: 09 November 2009, 21:49:23 »
Already given it a go with the GM wrench but I can try again tomorrow after locating some more leverage (and when it's not quite so freezing outside).
« Reply #5 on: 10 November 2009, 00:23:59 »
I was in Runcorn all day today but I only live about 1/2 an hour away so if you PM me your number I can bring my breaker bars with me ;)
« Last Edit: 10 November 2009, 00:25:11 by Elite_Pete »
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #6 on: 10 November 2009, 00:50:45 »
10ft scaffold tube, with someone else's boot on the GM wrench.
damage consultant
  • falkirk (sunny scotland)
« Reply #7 on: 10 November 2009, 18:24:21 »
if you strip the lock nut best way to get security nut off is to get a long IMPACT socket that is a tight fit (if 19mm use 18 or 17) on the locking  stud head and hammer it on the stud  then use a 1/2 breaker bar to remove trust me it works
Martin_1962
« Reply #8 on: 10 November 2009, 20:32:18 »
I carry a breaker bar and 17mm impact driver with me.
First Omega killed the supplied wrench
zirax
« Reply #9 on: 10 November 2009, 21:38:47 »
Handy to remember thanks :)
Normally I do carry these and a torque wrench but I was racing a couple of weekends ago and took it out for the MR2 :(
I could have worked this out, the locking nut has a collar on it. I couldn't get enough purchase using the GM wrench so took it to a mechanic in the area. He showed me it slipping off. I didn't see him put the locking nut on the wheel but having looked at the nut a few mins ago I think he tried it with the collar extended, hence it was gripping with a tiny bit and slipped  :-[ Something to try tomorrow and I'll let you know what happens.
« Last Edit: 10 November 2009, 21:40:24 by zirax »
