Author Topic: To chip or is it chipped  (Read 2011 times)
relluf
« on: 11 November 2009, 12:06:29 »
Hi folks
I have had my 98 td estate man since feb and have sorted out most of its niggles , she now starts first time and the eml light stays off nearly all the time (diesel magic).
Next on list is chipping ,now my question is is it possible to tell if it has been done already? To be honest the performance is pretty lively already although i am not sure what to measure it against our other car is a 1.9 jtd fiat and they are about comparable at the moment, should the miggy be noticably better? can i open up and look at chip?what am i looking for if i do?
any thoughts anyone?
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: To chip or is it chipped
« Reply #1 on: 11 November 2009, 13:57:07 »
Hi folks
EML, try paperclip test, some TD's are clipable.
TD Chips, worth doing for more power and better MPG but only if you have a Manual Box.
Aready Chipped, probably not if its a Auto, you can take the ECU apart and look at the Eproms, someone may have bothered to label them (Superchips do) but Im guessing no give away and not labelled.
Why not go on some meets (see Meetings Section) and have a chat with some other OOF'ers with TD's to compare.
Chris.
relluf
« Reply #2 on: 11 November 2009, 17:26:02 »
Thanks for input , i am familer with paperclip test etc and am quite happy with how she is running, i guess what i am asking is before i open up chip housing etc am i going to be able to identify a standard chip as oppose to a retro fit?
zirk
  • Epping Forest
« Reply #3 on: 11 November 2009, 18:07:47 »
No your not, thats why I said earlier unless someone has bothered to label it, There not chip's as such but eproms (memory), so the actual eprom is the same type just programed differently, so its going to have the same chip name and type on it.
The oringinal eproms may have a ident label on them (normally silver foil type) but Ive seen originals that are blank.
People like Superchips and Courtenay put there own labels on and sometimes there piggy backed into another PCB with some addintional chips to prevent copyright.
Another giveaway could be if its a 'solder in' eprom (rather than push in), then chances are its original, unless someone has desoldered and soldered a different one, in which case you should be able to spot this.
Take the ECU apart and have a look.
there's a 'How to' here:
http://www.omegaowners.com/forum/YaBB.pl?num=1232908603
relluf
« Reply #4 on: 11 November 2009, 18:33:10 »
Thanks  :y
Thats what i needed to know before I opened the ecu box, Chances are I may be able to tell.
Didnt mean to cause offence i meant familiar with paperclip test. :
zirk
  • Epping Forest
« Reply #5 on: 11 November 2009, 18:46:27 »
Thanks  :y
No offence at all Franks Dad :y
Do take a note of the Auto / Manual Box thing though, if 2.5 TD Auto's are Chipped, the Gearbox wont last long.
Chris.  :y
Omegatoy
  • UK
« Reply #6 on: 11 November 2009, 19:04:31 »
there may be a way to tell quite easily!!
every 98 car i have come across has had a soldered chip in it, if it has been chipped then it will have a chip holder in it??? :y
Richard A
  • Aldridge, West Midlands
« Reply #7 on: 11 November 2009, 19:54:22 »
As already said, 'do not chip an auto' the AR25 auto box is not made to take the extra BHP.
regards
richard a
richard a
« Reply #8 on: 11 November 2009, 19:57:50 »
regards
richard a
Its the extra torque that sees them off :(
« Reply #9 on: 11 November 2009, 19:58:15 »
regards
richard a
Torque is the killer, rather than bhp :y
but you're right, it will kill ar25 quickly.  I think mrs omegatoy almost managed 100 miiles ;D
« Last Edit: 11 November 2009, 20:07:11 by TheBoy »
« Reply #10 on: 11 November 2009, 19:59:07 »
If the sticker on both eproms looks the same, chances are, its std chip. If one of them is different colour/font/printer, chances are its modified
relluf
« Reply #11 on: 11 November 2009, 20:51:30 »
 :yOnce again thanks guys
I will have a look inside the ecu over the weekend.
It is a manual
Omegatoy
  • UK
« Reply #12 on: 11 November 2009, 20:51:45 »
regards
richard a
nearly!!!! 92 to be exact!!! ;D
