Author Topic: OIL LACK WARNING?and what is that pipe?  (Read 2060 times)
pcd
  • oldham
« on: 10 November 2009, 11:37:42 »
Hi,can any one tell me where the OIL LACK SENSOR IS? i know that its faulty as oil levels are spot on,but while this warning is on my computer wont give me any other info,also in the engine compartment just behind the power steering top up tank i have what seems to be a fuel filter which has a pipe fitted to the bottom but only has a small bent rubber pipe coming out of the top,going no where,should there be somthing conected to this,maybe a vacume pipe,its a 2.5 tdi 1997?ALSO I WOULD LIKE TO CHIP THIS CAR WHICH IS THE BEST CHIP TO GO FOR,cheers to every one who as helped me before use to be an audi driver,im realy getting to like my elite and this forum as proved fantastic help,cheers
         pcd
oceansoul
  • Sunbury on Thames - Surrey
Re: OIL LACK WARNING?and what is that pipe?
« Reply #1 on: 10 November 2009, 12:38:19 »
Do you mean the check oil level warning on the Info screen? Mine comes up occasionally. You can clear the warning by pressing the large button on the wiper stalk and continue to use the Info Display.
platty
  • Cambridge
    • BMW 530d Sport
« Reply #2 on: 10 November 2009, 13:35:05 »
My TD gives out this code from time to time, seemingly random.
I just ignore it as I keep a keen eye on the oil level anyway.
  • Auckland
    • Mazda MPV
« Reply #3 on: 10 November 2009, 13:51:38 »
On my 94 2.5 V6 petrol it used to occasionally show either 'check oil' or 'oil lack' if I let the level fall below half way on the dipstick.
I never did work out what the difference was & after the initial panic  :o realised that it gave me plenty of warning that I needed a top up (about 1000 miles early ::) )
On the V6 petrol you have to drop the oil pan (sump) to get to it. Don't know where it is in the diesel.
« Last Edit: 10 November 2009, 13:54:32 by andyh »
oceansoul
« Reply #4 on: 10 November 2009, 14:15:40 »
Do all omegas say "Oil Lack" at below half? Mine occasionally comes up saying "Check Oil Level" which at first concerned me. But now i just ignore the Warnging and check my level weekly. I didnt know it would shout at me when im Lacking oil tho.   Glad i read this thread (sorry i couldnt be of any help tho :-/ )
pcd
  • oldham
« Reply #5 on: 11 November 2009, 00:29:24 »
the lack oil warning stays on all the time even after using the check button,i think its cause it would be important if in fact the level was low,i could do with knowing where the sensor is,on the engine to make sure that the electrics are sound,also any one any ideas on the second part of my post.cheers
Richard A
  • Aldridge, West Midlands
« Reply #6 on: 11 November 2009, 20:31:28 »
'Oil Warning' tends to show on slow inclines on motorways, always worth just to top up to 'full' level.
CHIP 2.5 diesel, only if an manual, the AR25 auto box will fail with the extra BHP.
regards
richard a
richard a
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #7 on: 12 November 2009, 09:12:11 »
pm sent  :y
