Author Topic: Cambelt V6 aaarrrgghhh!  (Read 2081 times)
Goonybird
  • Northampton
  • Shouldn't have gone to Specsavers
« on: 10 November 2009, 14:18:02 »
Took this week off to do the cambelt on my 2.5V  V6.
so far so good until refitting the new cambelt. Have got the infamous OOF DVD! Locking kit & Gates kit correct for this engine no. New idlers fitted (checked as correct type) Belt checked and matches old one.
With the double white lines correctly positioned at the notch on the crank. the 2 white single lines are easy to line up on banks 1&2. But the two white line for banks 3 & 4 don't even come close. The belt matches the one taken off so what am I doing wrong. I have slackened the tensioners.
note the in the first picture the marks are a notch out on 1&2 as the belt is on just for the piccies
Piccy of Bank 1&2
3&4
Any relevant advice most welcome
« Last Edit: 10 November 2009, 14:18:54 by goonybird »
Have owned: Opel Manta A 1900 Auto Berlinetta, Opel Manta B 2.0 Auto Berlinetta, Vx Royale Coupe 2.8 Auto, various non Vx, Skoda Superb 130tdi currently Omega 2.5CDX - now Octavia vRS WRC
Re: Cambelt V6 aaarrrgghhh!
« Reply #1 on: 10 November 2009, 14:41:26 »
Can't see the pics at work - but, if it's a later (post 97?) engine, you'll need to use the yellow marks on the belt, not the white ones...
barclay03
  • Glasgow
« Reply #2 on: 10 November 2009, 15:13:08 »
did you turn that tensioner so the larger side is at the top, and see and try it again?
Goonybird
  • Northampton
« Reply #3 on: 10 November 2009, 15:23:10 »
Thanks
Ahhh! go and try that as its a '99 model mini facelift.
wondered what the yellow marks were for!
stef
*yup that works. better get on with then.
Quick tip for anyone doing the cambelt use pegs to hold the belt on each camshaft cog! ;)
« Last Edit: 10 November 2009, 15:40:35 by goonybird »
« Reply #4 on: 10 November 2009, 15:50:36 »
Glad it worked. Is it running?  :D
Goonybird
  • Northampton
« Reply #5 on: 10 November 2009, 17:08:10 »
Stopped work as it is weeing down. Got the belt on.
Just need to tension and re-assemble.
Last big job I did on a car was in the 1980's for the VX Royale Camshaft and followers.
Took two of us to lift the head off!
* for the younger members thats a 2.8 straight six with Iron Block and Iron Cylinder Head.
Martin_1962
« Reply #6 on: 10 November 2009, 20:33:27 »
I saw it - thought yellow marks needed there
Goonybird
  • Northampton
« Reply #7 on: 12 November 2009, 11:38:11 »
Just a short one to say thanks again for the help.
Finally got the car running this morning. Delays due to cr4p weather.
Initially worried on starting as smoke poured out  from cam cover area  :-?
I think I got water on the drive belt causing it to slip.
After checking wiring everything seemed ok and fine when restarted.
Runs a treat. flushed and refilled with the red stuff mix and all seems fine.
Sounds marvellous at 6,500 rpm.  8-)
I'm loving it. (until the next thing goes wrong!)
Stef
« Last Edit: 12 November 2009, 11:38:33 by goonybird »
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
« Reply #8 on: 12 November 2009, 12:03:28 »
a job well done.  :y
ScaniaV8
  • Luton, Bedfordshire
« Reply #9 on: 12 November 2009, 12:31:44 »
From your pictures it looks like a nice new Water pump fitted too  !  :-)
Glad you managed to fit the cam belt ok... I watched the expert Darth-Loo-Knee (the Omega God from Stoke) do mine recently...poetry in motion  :-)
