Author Topic: Advice required  (Read 6249 times)
Ziad
  • Bahrain
Advice required
« on: 05 October 2009, 02:56:50 »
Now guys, it may have been asked before, but I would appreciate a little bit of insight here. Below are the symptoms:
I've noticed that the car pulls to either direction since a week or two. Sometimes it pulls to the right, sometimes to the left and sometimes it's just fine. There's definitely vibration through the steering column at speeds above 130 - 140 kph. Whenever I brake, the car again pulls either to the right or to the left. Now, she's started to wear the front tyres on the outside (both right and left!).
What could this be according to you guys?
Cheers,
Z
Jamieo
Re: Advice required
« Reply #1 on: 05 October 2009, 04:16:25 »
That is definately a sign that your front wishbone bushes are gone. You will need complete new wishbones unless you have access to a press to press out the old bushes and press in new ones.
Re: Advice required
« Reply #2 on: 05 October 2009, 05:37:19 »
Def sounds like wishbone bushes, as said. I think Entwood on here had outside edge ware when his went.
When you fit new ones remember to torque the bolts correctly with the car on the ground, suspension loaded. Its a bugger with access and a long handled torque wrench under the car but it is possible. I did my bolts up loosely fists, reversed the car gently up and down the drive a bit and then torqued them up. Hth :-)
Omegatoy
  • UK
Re: Advice required
« Reply #3 on: 05 October 2009, 09:16:51 »
well the symptoms dont sound like wishbones to me? its to varied, reckon its more likey to be play in the steering idler to be honest?
Re: Advice required
« Reply #4 on: 05 October 2009, 10:12:58 »
Also worth a check.... As are all othe components.
Must admit i was suprised with Entwoods symptoms, but was diagnosed by WIM, and cured the problem. Assuming i remember it correctly of course.....?
Re: Advice required
« Reply #5 on: 05 October 2009, 10:21:13 »
Mine was outer edges and all sorted by wishbone changes ...
full details in this thread
http://www.omegaowners.com/forum/YaBB.pl?num=1242682251
HTH
Ziad
  • Bahrain
Re: Advice required
« Reply #6 on: 05 October 2009, 21:37:52 »
Thanks for the advice guys. I'll be taking the car to the guy who usually repairs the mig and have him check the wishbones and steering idler. Will post up the results when it's done  :y
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
Re: Advice required
« Reply #7 on: 05 October 2009, 22:36:13 »
Usually inside wear is due to camber being out (eg worn wishbone front bushes).
Outside edge is usually tracking.
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: Advice required
« Reply #8 on: 05 October 2009, 23:07:58 »
it could allso be the steering pin, think im going to get mine done as its abit lose and dose the same thing, my bushe's are new.
Ziad
  • Bahrain
Re: Advice required
« Reply #9 on: 07 October 2009, 00:42:44 »
Your surely mean the steering idler R?  :-/
rustym95
Re: Advice required
« Reply #10 on: 07 October 2009, 04:10:39 »
nope half moon with pin, snaps in a crash so you dont get spiked after the air bag go's., I can see it when push back the rubber inside.
« Last Edit: 07 October 2009, 04:11:22 by Russell_Hill »
Ziad
  • Bahrain
Re: Advice required
« Reply #11 on: 07 October 2009, 04:49:25 »
Alright mate. Anyway, the whole rather suspension will be checked and whatever needs to be changed will  ;) :y
Thanks for the info  :y
  • Auckland
    • Mazda MPV
Re: Advice required
« Reply #12 on: 07 October 2009, 08:34:02 »
Are you referring to the shear pin in the energy absorbing collapsible steering column? http://en.wikipedia.org/wiki/Steering#Safety
Ziad
  • Bahrain
Re: Advice required
« Reply #13 on: 09 October 2009, 11:57:43 »
Just something I wanted to ask again guys. If i am to  check for play in the track rod / steering idler and droplinks, can i do so with the car on the ground? I actually have access to a shop where the car stays on the ground and I can go underneath  :-/
Also, what would be the correct camber / toe settings for the mig??
« Last Edit: 09 October 2009, 12:03:53 by ziad »
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
Re: Advice required
« Reply #14 on: 09 October 2009, 21:11:48 »
Jack up passenger side front and get someone to wiggle the wheel by holding the tyre in the 3 and 9 o'clock positions whilst you watch the Steering Idler. Any vertical movement means it needs to be replaced.
