Author Topic: what size alloys can be fitted?  (Read 1418 times)
mathewst
  • Split, Croatia
    • v40
« on: 12 November 2009, 13:13:32 »
Well I'm back on the forum after a flue.
Still not feeling very well but the blasted work can't wait too long.
Ok won't bother you guys with problems but want to know a few things.
I've talked with my fioncees' brother in law.
He used to have a mig and said he normally put Mercedes Benz alloys on it.
Is this possible?
I know Opel/Vauxhall alloys are 5x110 and Mercs are different.
If it iss possible can it cause any problems?
Ian_D
  • York
Re: what size alloys can be fitted?
« Reply #1 on: 12 November 2009, 13:19:38 »
I have seen merc alloys on a Vectra. I think they have to use wobble bolts to fit them though.  :-/
[size=12]
mathewst
  • Split, Croatia
    • v40
« Reply #2 on: 12 November 2009, 13:24:35 »
Actually don't want to put mercs alloys but there is one crashed c class mercedes with great looking Alessio 17 alloys and maybe the guy will want to sell them
MV6Matt
  • London
    • No car since 2022....
« Reply #3 on: 12 November 2009, 14:10:03 »
As Ian says if they're 5 x 108 or 5x 112 then you can use wobbly bolts.
Anyone confirm Merc Pcd?
Matthew
(thanks Ian)
mathewst
  • Split, Croatia
    • v40
« Reply #4 on: 12 November 2009, 14:15:59 »
What are wobbly bolts?
SJKOO01
« Reply #5 on: 12 November 2009, 15:22:28 »
Is this possible?
Hi,
if the links have worked correctly (see below), try looking at the list which will explain each manufacture pcd and centre bore spec's.
Basically whilst not a cheap way of doing it, at least you'll know that the wheels will sit on the hub correctly.
Hope it helps ?
http://www.demon-tweeks.co.uk/products/ProductDetail.asp?cls=ROAD&pcode=H/R3055571-665
http://www.demon-tweeks.co.uk/resources/pdfs/HR_Adapter_08.pdf
MV6Matt
  • London
« Reply #6 on: 12 November 2009, 18:04:12 »
Wheel bolts that have a 'cup' under the bolt head to allow a degree of movement as the bolts are done up to accomodate small differences in wheel Pcd and recieving hub size.
As mentioned before only work +/- 2mm
HTH
Matthew
« Last Edit: 12 November 2009, 18:04:39 by MV6Matt »
(thanks Ian)
mathewst
  • Split, Croatia
    • v40
« Reply #7 on: 12 November 2009, 21:31:23 »
I've checked them on ebay and they are pretty expensive I must say, with posatge around 65 pounds and that is not a small amount.
I guess I'll stick to my alloys but have to have them wellded and painted
i260
  • Newport, South Wales
« Reply #8 on: 14 November 2009, 04:55:51 »
merc rims are 5x112 - the vw guys use them. Could also consider Bently rims then!  ;D
Personally I dont like the idea of incorrect fitment wheels botched to fit- its all that is holding you on the road!
« Last Edit: 14 November 2009, 04:57:28 by i260 »
Saab 9-5 Aero 260ps
