Author Topic: Central Locking Stopped Working...  (Read 3088 times)
MutantCav
  • Gainsborough
« on: 07 November 2009, 19:48:03 »
Ok 95 3.0 manual elite estate...got the car dead cheap as the Zafira broke down (oil pump failed one week after I replaced the master cylinder...useless piece of sh*******).
So the Omega runs fine apart from a couple of known issues...bolt head has sheared off on the oil pump so leaks oil above about 3000rpm so oil needs topping up now and again...and exhaust manifold gasket leaking...neither much of an issue to me as its a temporary get out of jail pretty much free jobbie :)
When I got it the central locking worked both on key and the fob...after a couple of days, it just stopped working and hasnt worked since on the fob or the key...fob has new batteries and the light comes on...but as the key doesnt set the central locking I assume its a central locking issue rather than fob anyway...
So any thoughts, central locking ECU, motor in drivers door, or maybe something else??
Any advise appreciated :y
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: Central Locking Stopped Working...
« Reply #1 on: 07 November 2009, 19:50:21 »
have you syncronized the key?
« Reply #2 on: 07 November 2009, 20:29:09 »
Come on Daz!!! Keep up!!  ;)  ;)  ;)  ;) :y
« Reply #3 on: 07 November 2009, 20:33:10 »
Fuse 20 Chris?
Courtesy lamp, seat heating, central locking & rear blind.
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #4 on: 07 November 2009, 20:33:29 »
Hey Bully Boy  ;D ;D ;D
I would try putting the key into the ignition and press the buttons (which I know you know how to do) see if this cures the problem :y
Or have I said something wrong??? :P
Oh Tunnie I am on your side stuff the old timer ;D ;D ;D
« Last Edit: 07 November 2009, 20:33:57 by Loo-knee »
« Reply #5 on: 07 November 2009, 20:35:34 »
Hey Bully Boy  ;D ;D ;D .....
  ;D  ;D  ;D  ;D
and I thought you'd said you'd be my friend!  :'(
 ;D  ;D  ;D  ;D
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #6 on: 07 November 2009, 20:36:51 »
  ;D  ;D  ;D  ;D
 ;D  ;D  ;D  ;D
You know what thought did?? ;D
He followed a muck truck and thought it was a wedding ;D ;D ;D ;D
« Reply #7 on: 07 November 2009, 20:39:14 »
  ;D  ;D  ;D  ;D
 ;D  ;D  ;D  ;D
 ;D   ;D  ;D  ;D  ;D
No wonder you get bullied on the forum!!  :y
MutantCav
  • Gainsborough
« Reply #8 on: 08 November 2009, 09:44:09 »
Fuse 20 Chris?
Will check the fuses...never thought of that doh! lol :y
Seat heating works though...courtesy lights a bit iffy...worth a check anyway :y
« Last Edit: 08 November 2009, 09:46:13 by ShieldOfSteel »
MutantCav
  • Gainsborough
« Reply #9 on: 08 November 2009, 09:45:14 »
I believe thats the first thing I tried...I reckon it would work on the key though even if not synchrinised with the fob??
Welung666
« Reply #10 on: 08 November 2009, 10:05:26 »
Chris, most likely drivers door motor, it's not triggering from the remote lock/unlock therefore not kicking the other motors in either.
MutantCav
  • Gainsborough
« Reply #11 on: 08 November 2009, 10:54:50 »
I have a spare one of those in the garage that I know works but its from a 98...will it be the same as the 95 model do you think??
giffila
« Reply #12 on: 08 November 2009, 16:41:48 »
Definitely not the same key type, 95 send via infrared, but 98 is radio frequency type. Resync yor key everytime replace a batteries is the most forgotten issue.
« Reply #13 on: 08 November 2009, 17:11:26 »
But the actual motor in the door is likely to be the same.
Chris's problems seem to lie in the locking mechanism or central locking module because if you read his original post the car doesn't centrally lock even using the olde fashioned method of putting the key into the lock. It's nothing to do wit re-sync'ing keys or batteries in the keys.  :y
« Reply #14 on: 08 November 2009, 17:48:15 »
You are probably using the key to unlock/lock the door, if checking the fuse and that is ok, then it seems the solenoid on the drivers door is the issue.
Does the central locking work on the boot lock when you use the key?  (never used my boot key but am assuming works the same as my carlston CDi did.
