Author Topic: Strong smell of diesel inside the car  (Read 1200 times)
Welung666
« on: 11 November 2009, 21:04:49 »
Only started last night. When I first start there is a strong smell of diesel inside the car, it fades a lot but I can still smell it throughout the journey (3 miles to work). I changed the leak off pipes a couple of months ago so unlikely it's those causing it. Any suggestions on where to start looking?
Abiton
Re: Strong smell of diesel inside the car
« Reply #1 on: 11 November 2009, 21:09:32 »
I've no idea whether the diesels have a similar tank arrangement to the petrols, but this thread comes to mind as possibly being relevant:
http://www.omegaowners.com/forum/YaBB.pl?num=1186065848
Welung666
« Reply #2 on: 11 November 2009, 21:19:08 »
A possibilty, I'll check that out. Although it seems to be coming from the vents so I'm edging towards an underbonnet leak.
Omegatoy
  • UK
« Reply #3 on: 11 November 2009, 21:25:39 »
had one meself and it turned out to be the long leakoff pipe from injectors to pump had got a pinhole in it!!
« Reply #4 on: 11 November 2009, 21:30:39 »
leak-off, leaky injector, fuel pipes, either at injections or at fip, fuel filter
Welung666
« Reply #5 on: 11 November 2009, 21:34:20 »
Thanks for the suggestions fella's. It's a bit dark now, I'll have a mooch tomorrow :y
Welung666
« Reply #6 on: 12 November 2009, 10:21:22 »
Had a look in the light of day.... fairly dry in the injector wells (5 & 6 are a little damp though) and all dry below. Seems to be a wet strip between the starter and block heading downwards but can't really see without dropping the plenum chamber off. I don't fancy doing that as I only changed the gaskets Saturday  >:(
« Reply #7 on: 12 November 2009, 10:23:41 »
I wonder if you have knocked/loosened/not tightened something duing that work .. seems very coincidental to me ....  :-/ :-/
Welung666
« Reply #8 on: 12 November 2009, 10:25:03 »
Knowing me yes ;D ;D I'll have to pull it back off again but I ain't happy :(
Welung666
« Reply #9 on: 13 November 2009, 12:49:47 »
Pulled up from work this morning and there was a lovely circular oil slick on the wet road where I turned around ;D ;D So I had a closer look and it's definately coming from round cylinders 5 and 6, injector side. I'll have to have the intake plenum off again in the morning to actually find it though. The odd thing is the lower part of the head that I can see with my mini maglite is bone dry, it's on the block that the trail continues downward.
damage consultant
  • falkirk (sunny scotland)
« Reply #10 on: 13 November 2009, 18:57:49 »
have you checked the feed/return that goes through the m/fold or cracked injector feed pipe to 5/6
Welung666
« Reply #11 on: 13 November 2009, 19:05:34 »
That's what my money is on, very strong smell under the bonnet with just the ignition on. I'm stripping it in the morning but I've got to go up to Lincoln tomorrow lunchtime  ::) bl00dy typical ;D
Welung666
« Reply #12 on: 14 November 2009, 13:54:25 »
Well I'd have lost my money ;D ;D
I changed the leak off pipes just over a month ago, the end plug on injector #6 was new too. Stripped the plenum off and what do I find? The end stop was swolen and loose so the fuel was just pouring out of it! Replaced it with an inch of leak off pipe with a very tight bolt. Problem solved :y
