Author Topic: Water Pump  (Read 1055 times)
Water Pump
« on: 14 November 2009, 17:25:11 »
Well my water pump on the saloon decided to self destruct yesterday.  Emptied all the coolant onto the road (really p*ssed off as only refilled with fresh water and new red antifreeze a couple of weeks back when I changed heater matex  :( )  Had it recovered back home.
Got more antifreeze and swapped it out this morning with a new GM pump I had in the garage.  The bearing on the old one had collapsed hence the leak.  Straightforward job (although the old one took some hammering to remove), topped up with 5 lits of A/F plus some water.  Had a good burn down the local dual carriageway - no leaks, heater nice and hot and coolant levet ok.
Job done  ;)
  • Auckland
    • Mazda MPV
Re: Water Pump
« Reply #1 on: 14 November 2009, 17:34:21 »
Well done  :y
Did you have to remove the cam belt to get the backplate off to get to the water pump?
Re: Water Pump
« Reply #2 on: 14 November 2009, 17:35:57 »
No cambelt not in way.
Re: Water Pump
« Reply #3 on: 14 November 2009, 17:37:20 »
Water pump is aux belt driven on the V's unlike cam belt driven on the 4 pots
  • Auckland
    • Mazda MPV
Re: Water Pump
« Reply #4 on: 14 November 2009, 17:46:20 »
I knew that it was driven by the auxiliary belt, I was just puzzled by the advice often given to change the pump when the cambelt was off.
Re: Water Pump
« Reply #5 on: 14 November 2009, 17:50:43 »
Coz once you get to the water pump it would only take another 10 mins to do a cambelt change!!
