Author Topic: looking for a good diy lpg kit  (Read 1201 times)
sara1983
« on: 14 November 2009, 23:25:11 »
Im looking to convert my 3.2 to lpg for obvious reasons.what make should i go for? I know i need a multipoint and would fit a donut type in place of the spare.Advice appreciated.
Re: looking for a good diy lpg kit
« Reply #1 on: 15 November 2009, 03:32:07 »
myself Kevin Wood, Lazydocker amongst others have fitted the stag front end kit. Rear end, i have as you describe, a donut tank in the spare wheel well, which is more expensive than the bigger capacity cylinders the others have across the back seats.
Lazydocker will be along with supplier details no doubt. Or pm him if you wish. Iirc its about 800 plus with an upright donut(tyroidal)tank. 700 odd with a cylinder. Something like that anyway.
The kit works very well. But has a small hic up at the top end around 6k as mine stands at the moment that affects the drive by wire cars.(3.2 and 2.6) no biggy as its not often driven in that range, but just to make you aware.
Hth
sara1983
« Reply #2 on: 15 November 2009, 13:35:29 »
there is a  front end stag kit on ebay,is this ok?.also  the donot types come up second hand, but it seems to me there are two types. what one doi go for.
« Reply #3 on: 15 November 2009, 13:37:27 »
if i LPG mine, which is very possible soon. I would go for the stag kit  :y
« Reply #4 on: 15 November 2009, 13:53:02 »
Another recommendation for the Stag kit. :y
Regarding doughnut tanks you need a vertical toroidal tank. Most are designed for horizontal mounting and aren't suitable. I'm sure chrisgixer can confirm the type that fits the saloon. Very neat it looks too.
EDIT: the above assumes you have a saloon. On the estate you don't need a vertical tank, obviously.
« Last Edit: 15 November 2009, 13:54:00 by Kevin_Wood »
« Reply #5 on: 15 November 2009, 15:55:38 »
I wouldn't buy the one from ebay as it's not a full Stag kit :y :y :y Plus you only get the components for that price... No pipework etc :y
I'll PM you the details of our supplier.
Oh.... ANd another vote for the Stag kit :y :y
sara1983
« Reply #6 on: 15 November 2009, 20:50:07 »
thanks to everyone for the advice
