Author Topic: abs/traction control lights  (Read 1340 times)
dreads
  • london
« on: 15 November 2009, 21:52:22 »
can anybody tell me if there is a fix for intermittent abs/traction control lights.sometimes they come on,sometimes off,but more on than off!!!    [smiley=angry.gif]
Ziad
  • Bahrain
Re: abs/traction control lights
« Reply #1 on: 15 November 2009, 21:58:11 »
Have your brake wear sensors checked or changed. If this does not solve the issue, then you might have a problem with your ABS ECU.
First point of call would be to try to clean the brake wear sensor and see if it cures the problem  :y
By the way, Hello and welcome to the Forum. Pop in to the Newbies section and say Hi  ;)
« Last Edit: 15 November 2009, 21:59:23 by ziad »
« Reply #2 on: 15 November 2009, 22:00:22 »
Sod all to do with wear sensors. More like your suggestion of ABS ECU, which is a common issue with 98 onward cars  :y
dreads
  • london
« Reply #3 on: 15 November 2009, 22:08:16 »
thanks for the info im still learning how to use the site!!
Ziad
  • Bahrain
« Reply #4 on: 15 November 2009, 22:11:00 »
Was just a suggestion as this would be cheaper than having the ABS ECU replaced or sent for reman  ;) :y
« Reply #5 on: 15 November 2009, 22:20:29 »
Lots of things would be cheaper than sending it to BBA repair ... but would they be relevant to the ABS ECU???? :y  :y :y  :y  :y
Ziad
  • Bahrain
« Reply #6 on: 15 November 2009, 22:24:52 »
You're right Andy, wouldn't be relevant. We'll stick to the culprit being the ABS ECU then  ;) :P
« Reply #7 on: 15 November 2009, 22:26:42 »
 :y :y  :y  :y
« Reply #8 on: 15 November 2009, 23:14:17 »
Agreed likely nackered abs ecu.  Either replace with good 2nd hand one (~ £45 -£55 from a breaker on here) preferably from exact year/model as yours (no Tech2 work needed then) or send yours off to say BBA for repair (~£130 )
You will probably find your speedo will also pack up, no cruise control and you will lose some power assistance on the steering.
Bu**er of a job to swap - limited space and can't see 3 of the 6 fixing bolts!!
Nothing to do with brake wear sensors - they just sense lack of brake pad thickness!!
