Author Topic: 2.6 Exhaust Manifold on 2.5 engine  (Read 1163 times)
« on: 15 November 2009, 16:54:48 »
Hi Guys
I'm fitting 2.6 manifolds to my 2.5 as one of a few upgrades.
Am I right in thinking I need to use the 2.6 exhaust manifold gaskets, rather than  2.5 ones?
If so, anyone have the part number for said gaskets please?
The part  I have here is 24416110 - which I believe is the gasket for 2.5 and 3.0 and hence not suitable?
Re: 2.6 Exhaust Manifold on 2.5 engine
« Reply #1 on: 15 November 2009, 16:58:18 »
I wonder why the changed them, the heads are basically the same  :-/
« Reply #2 on: 15 November 2009, 17:24:00 »
I think it's to do with the SAI...
« Reply #3 on: 15 November 2009, 17:26:12 »
Yes, you need the 2.6/3,2 gaskets....you also need to chop about 5mm off the lip at the top of the front pipe.
Not got a clue about the part number though.
They do flow better and are nicely made!
  • Auckland
    • Mazda MPV
« Reply #4 on: 15 November 2009, 17:29:01 »
Yes. I think the lighter manifolds absorb less heat to allow the pre cats to warm up quicker.
« Last Edit: 15 November 2009, 17:30:18 by andyh »
« Reply #5 on: 15 November 2009, 17:30:49 »
Cheers Mark
Do you think the benefits will be noticable? Would it be beneficial to port the exhaust ports at all, or not?
« Reply #6 on: 15 November 2009, 18:07:31 »
As per the engine basics, exhaust port porting makes little to no difference as the gases are not pumped.....and compared to the restriction of the bog standard manifolds.....
« Reply #7 on: 15 November 2009, 20:21:05 »
EPC states these for 2.6/3.2  MANIFOLD,EXHAUST (FOR CYLINDER NOS. 1,3,5)     24422261
18  MANIFOLD,EXHAUST (FOR CYLINDER NOS. 2,4,6) (NLS.)      24422262
GASKET,EXHAUST MANIFOLD
 12992739
Martin_1962
« Reply #8 on: 15 November 2009, 22:21:40 »
Hi Guys
I think I'd fit the whole lump
« Reply #9 on: 16 November 2009, 08:48:54 »
Hi Guys
I would not bother, no advantage unless you can get the compression back up.
