Author Topic: cam cover black goo and breather box gasket.  (Read 1077 times)
« on: 17 November 2009, 07:51:48 »
going to do my cam covers this weekend.
 I have the gaskets and o rings but the parts man tells me the sealent for the corners is the same stuff as for the oil cooler cover plate. I have noticed the part number in the guide, but i thought the two where very different. Black goo for cam covers, grey goo for oil cooler plate?
Just wanted to make sure is all. I think i used a loctite product from halfords last time?
I also thought i would have a dig around in breather box and remove it. I imagine access will be easier with the inlet removed etc? But question is does it have a gasket or sealent. I imagine gasket? I'll get one if so.
Cheers
Chris. :-)
Re: cam cover black goo and breather box gasket.
« Reply #1 on: 17 November 2009, 08:11:24 »
the stuff i used to seal the cooler plate was very different to the black stuff i used on the cam cover gasket as far as i remember!
« Reply #2 on: 17 November 2009, 08:11:29 »
The cam cover gaskets DO NOT use the same sealent as the oil cooler plate.
The breather box to block does use the oil cooler plate sealent.
« Reply #3 on: 17 November 2009, 08:56:50 »
thanks guys, i'll quote the part number in the guide at them and leave it at that i think.
I have same grey goo left over but i think its out of date. I take it its ok to use if its not dried out (which it may well have done by now.) ?
« Reply #4 on: 17 November 2009, 09:01:50 »
If its not dry it will be fine (they do often go to a hard amorphous lump!)
