Author Topic: fixed lower cambelt idler on 2.5  (Read 1156 times)
« on: 17 November 2009, 20:30:47 »
Does anyone know if the fixed lower idler can be fitted to a late 2.5 engine - or is the concentric one absolutely required?
I have a 2.6 kit spare, I'll use the pulleys off it for my 2.5 if that idler will fit...
Re: fixed lower cambelt idler on 2.5
« Reply #1 on: 17 November 2009, 20:31:29 »
Just to clarify, what I'm asking is, will the timing be correct on the 2-4-6 bank, with the lower idler fitted, to the 2.5 lump... or does it need the concentric one to set it..
« Reply #2 on: 17 November 2009, 20:34:50 »
Should be spot on if the heads have not been skimmed
« Reply #3 on: 17 November 2009, 20:47:27 »
That's what I thought, but wasn't 100% sure having never done it - thanks Mark :y
« Reply #4 on: 17 November 2009, 20:48:46 »
Does fitting new pulleys to old backplate cause any issues?
I can't see for one min that it would (especially with new bolts and a bit of thread lock)
Was Jimbob's just a bad component?
« Reply #5 on: 17 November 2009, 20:52:12 »
Backplate is no issue...jimbobs was just the fact it was covered in oil following machining!.
Wont make that mistake again!
Dazzler
  • Haverhill, Suffolk
« Reply #6 on: 17 November 2009, 21:11:07 »
Used the old backplate when i changed mine, i also fitted an adjustable pully instead of the fixed one.
No probs with any of it :y
