Author Topic: Aux drive belt size  (Read 1241 times)
acura
  • Lancashire
Aux drive belt size
« on: 17 November 2009, 19:58:40 »
Does anyone know the size of the aux drive belt for a 2002 2.2 CD auto? I got one from eurocarparts when I got the timing belt stuff but they sent one that is too short. The original belt shrieks a bit on start up and when I rev.
Thanks
From Consul 375 to Omega, 30 cars and counting.....
Re: Aux drive belt size
« Reply #1 on: 17 November 2009, 20:04:58 »
You sure they haven`t sent you a non-aircon belt :question As for the shrieking noise could be tensioner bearing, alternator bearing or waterpump bearing
« Reply #2 on: 17 November 2009, 20:06:18 »
have they sent you a 2.0 non-aircon one?
All 2.2 aux belts are the same size, as all 2.2's had climate.
acura
  • Lancashire
« Reply #3 on: 17 November 2009, 20:16:37 »
They probs have sent me the non-aircon belt  :( I suppose it'd be just as easy to get one from my local accessory shop as go through the rigmarole of sending this one back.
I sincerely hope the shriek is not the water pump as I changed it about 3 weeks ago  ::) No, the noise was there before that. Could be the alternator or tensioner. I thought it might be the belt itself losing grip as its a bit old and worn. The noise is only for a moment when the engine speed is increasing, not all the time, as if it slips a bit on the crankshaft pully.
« Reply #4 on: 17 November 2009, 20:20:36 »
Pop the aux belt off, and start the car (just for 30 seconds) see if the noise remains.
acura
  • Lancashire
« Reply #5 on: 17 November 2009, 20:55:10 »
Aye, will do. Cheers.  :y
Bully
« Reply #6 on: 17 November 2009, 21:31:37 »
The none air con model is 6 ribs wide and 1725mm long and the model with air con is 6 ribs wide and 1903mm long
acura
  • Lancashire
« Reply #7 on: 17 November 2009, 21:40:41 »
Cheers!
