Author Topic: Acceleration flat spot ANY HELP PLEASE  (Read 1399 times)
STAVROS MOONIE
  • Oldham,North West
« on: 17 November 2009, 23:25:52 »
Hi,could anybody please help with a slight glitch with my Mig 2.5 auto.When first setting off in drive or reverse the car stalls & when in neutral if I floor it revs drop suddenly and then more often than not engine dies.
Other than that the car runs as sweet as a nut.
Not so much of a problem most of the time but very dangerous on roundabouts as it launches three feet onto the roundabout and then stalls in drive  :(Any ideas please
Pete Elite
  • Uxbridge, Middlesex
Re: Acceleration flat spot ANY HELP PLEASE
« Reply #1 on: 18 November 2009, 02:38:11 »
Give the ICV a good clean(use carb cleaner,let it dry then put a few drops of 3in1 oil on the valve but don't poke the valve with anything metal and damage it)and if it's not been done for a while, the breather system as well, but the stalling will /should stop if you clean the ICV.
 Look in the maintenance section for how to clean the breather system :y.
capoMV6
« Reply #2 on: 18 November 2009, 05:09:50 »
Pardon my ignorance but what's the ICV?
Welung666
« Reply #3 on: 18 November 2009, 05:51:43 »
Idle Air Control Valve, on the V6's it's located passenger side at the front of the plenum :y
capoMV6
« Reply #4 on: 18 November 2009, 10:30:47 »
Thanks mate! Appreciate it! :y
STAVROS MOONIE
  • Oldham,North West
« Reply #5 on: 18 November 2009, 16:27:06 »
Hi Pete & thanks for that I will give it a go,Moo  :D
« Last Edit: 18 November 2009, 16:28:47 by MOONIE »
