Author Topic: HID upgrade  (Read 6405 times)
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
HID upgrade
« on: 18 November 2009, 23:02:27 »
Would an upgrade to HID's (O/E units, not the Fleabay kits) make big difference in actually seeing where I'm going and is it just a case of "plug and play" regarding the wiring ?
What about h/lamp washers and the self leveling linkage, how critical are they to performance etc ?
Omegatoy
  • UK
Re: HID upgrade
« Reply #1 on: 18 November 2009, 23:25:28 »
absolutely!!one of the  best upgrade ive done on mine, although i do have adjustable rear air shocks, i havent bothered fitting the sensors etc and had no problems with mot or anything else most people say you should fit all the gubbins, but as said the rear shocks on mine do set the beams where i want them!!
i actually soldered my hid wires into the loom infront of my original plug, so i can swap back almost immediately just by plugging in the original lights to the original wiring if that makes sense? ;D :y
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
Re: HID upgrade
« Reply #2 on: 18 November 2009, 23:33:11 »
So they won't plug straight in then ?
Re: HID upgrade
« Reply #3 on: 18 November 2009, 23:40:01 »
Nope, considered it for mine. The main problem i have fitting them is the lack of washer system.
We have a 3.0 Elite with HIDs and its amazing the difference washing them does to the light output. They are affected by road dirt much more than standard lights, hence washers are a legal requirement (on paper) but i see why they are needed.
It put me off putting them on mine, i stuck nightbreaker bulbs in and they bring it very close to HID output
Omegatoy
  • UK
Re: HID upgrade
« Reply #4 on: 18 November 2009, 23:42:15 »
i just wash mine every time i use it in dirty weather ;D but have to say i havent really noticed any degradation in the light output when they are dirty, but am sure there is if they say there is!!
Re: HID upgrade
« Reply #5 on: 18 November 2009, 23:44:23 »
I am doing 150 miles a day now, i given them quick wipe before i start. But driving along in mother tunnies Estate, i thought the windscreen looked a bit mucky (driving at night) gave it a blast, light output went up by around 30%  :o
joshwyatt
  • Oxford
Re: HID upgrade
« Reply #6 on: 18 November 2009, 23:55:03 »
I agree totally with Tunnie, headlight washers do serve a real purpouse. I would not even consider only fitting the lights, in my opinion you MUST fit the correct sensors to make the light motors work and headlight washers. I think it's bordering on unsafe and careless not to fit them. They are there for good reason, and by-passing them can only lead to trouble. I think not fitting headlight washers negates the whole point of fitting HID's...you want better light output so therefore you also need the headlight washers. And the light levelling motors are to avoid dazzling oncoming drivers. I know of an instance around here, that after investigation by TVP and other agencies an accidnet was attributed to a driver who thought he culd fit Xenon's without correct self levelling, blinded a driver coming over a small bridge, and caused them to crash, causing them to suffer fairly severe injuries and right their car off.
Quick answer, if you do it...please do it properly and fit headlight washers, and correct levelling motors etc.
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
Re: HID upgrade
« Reply #7 on: 19 November 2009, 00:26:22 »
I suspect the self leveling is only an issue when the rear drops with a heavily loaded boot, rear passengers, towing etc. but that would be easily adjusted by the in-dash leveling switch.
I have heard before that HID's are affected by dirty lenses more than std bulbs.
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
Re: HID upgrade
« Reply #8 on: 19 November 2009, 00:32:34 »
I have Nightbreakers fitted and they definately made an improvement, but I wouldn't say they're close to any HID's I've seen. If that's all the improvement is then I definately won't bother.
« Last Edit: 19 November 2009, 01:12:05 by Turk »
Re: HID upgrade
« Reply #9 on: 19 November 2009, 09:25:10 »
Other HIDs are another matter, brand new beemers pounding the outside lane tend to light up the whole 6 lanes  ;D
Omega HIDs aren't fantastic, when my 2.2 waterpump decided to die on me, i used mother tunnies Estate for a week, i liked the HIDs, when i got mine running again i was expecting to be plunged into darkness, but i found its not too far off. In poor weather the HIDs are much better, but under clear conditions, they are not far off.
If you do fit them, i highly recommend washers  :y
Omegadoha, Desert Member
  • Doha, Qatar
Re: HID upgrade
« Reply #10 on: 19 November 2009, 09:38:34 »
I thought the headlamp washer system was to stop dazzling other oncoming drivers?
Re: HID upgrade
« Reply #11 on: 19 November 2009, 09:42:30 »
Think the level sensors on the rear shocks are for that, washers are for keeping them clean  8-)
mathewst
  • Split, Croatia
    • v40
Re: HID upgrade
« Reply #12 on: 19 November 2009, 09:45:00 »
Nope, leveling motors are to stop dazzling oncoming drivers
  • Auckland
    • Mazda MPV
Re: HID upgrade
« Reply #13 on: 19 November 2009, 10:18:53 »
I agree. Dirt on the lenses either absorbs light or scatters it.
The scattered light contributes to the glare that other road users are subjected to.
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
Re: HID upgrade
« Reply #14 on: 19 November 2009, 15:25:08 »
I thought self leveling is connected to the front wishbones.
Pages: [1] 2 3 4  All   Go Up
