Author Topic: Auto diff in a manual car  (Read 1557 times)
gsizoli
  • Hungary
« on: 18 November 2009, 19:28:33 »
Hi!
What does it mean in practice if I use an auto diff (ratio 3.9) in a manual car (original diff ratio is 3.7).What about the speed, revs, 0-60, fuel economy.
Car is a 3.0 facelift.
Br
Zoli
  • Online Online
Re: Auto diff in a manual car
« Reply #1 on: 18 November 2009, 21:17:13 »
slightly higher revs for a given speed = worse fuel consumption.
your prop will need to turn 3.9 times for the output (drive shafts) turn once instead of the 3.7 times at the moment.
« Reply #2 on: 18 November 2009, 21:29:21 »
But slightly quicker getting there.
  • Online Online
« Reply #3 on: 18 November 2009, 21:35:54 »
That too!  :y :y :y .....
I was letting someone else have a turn too!  ;D
gsizoli
  • Hungary
« Reply #4 on: 18 November 2009, 22:17:50 »
Thanks guys, I understand now.I hope it will be okay for me, if not, I will look for a manaul diff with 3.7 ratio.But if the fuel consumption won't be much worse I don't care... :D
Ghost
  • Seaham, North East england
    • 2.6 V6 CDX Estate
« Reply #5 on: 19 November 2009, 00:10:13 »
Also check your spedo. ( tacho ) it might be out showing roughly 10 kmh faster or slower than you are moving.
He who brakes Looses
To old to die young
« Reply #6 on: 19 November 2009, 12:03:17 »
Not a probelm as the speedo uses the ABS signals which are on the diff output shafts  :y
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #7 on: 20 November 2009, 09:04:32 »
You'll probably notice slightly better acceleration and hill-climbing. Better for towing caravans too!
« Last Edit: 20 November 2009, 09:05:18 by Reliance505 »
  • Online Online
« Reply #8 on: 20 November 2009, 20:33:57 »
A 3.0 doesn't really need any help towing and I'd want any addition/modification to help fuel ecconomy not make it worse!   ::)  ::) ;)
« Reply #9 on: 20 November 2009, 20:39:12 »
In theory it could (note theory) as the auto box would go into lock up a few mph lower and it should change down slightly less
  • Online Online
« Reply #10 on: 20 November 2009, 20:41:00 »
Maybe .... but I generally get mine up to lock up speeds without problem.  :y  :y  :y
