Author Topic: 1996 Omega 2.5 cdx - water pump probs  (Read 2852 times)
froezen
  • Scarborough,UK
« on: 20 November 2009, 20:23:49 »
*EDIT - Due to replies, i'm gonna try and fix it!
It's an auto in black, and it broke down on me today  :-/
I think the water pump has siezed up as the accessory belt has shreaded.
« Last Edit: 21 November 2009, 00:25:05 by hotel21 »
Martin_1962
Re: FS 1996 Omega 2.5 cdx - Spares/Repairs
« Reply #1 on: 20 November 2009, 22:05:17 »
Put a new pump and belt on it
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
« Reply #2 on: 20 November 2009, 22:53:06 »
dont seem that there is alot wrong with it just needs some tlc,
would fix it my self, would be cheaper to fix than to get another one. :y
froezen
  • Scarborough,UK
« Reply #3 on: 20 November 2009, 23:51:44 »
True, but my problem is the car is stuck about 70 miles away from where I live. So, I could get it recovered home at a large cost then repair it. Or I could go and repair it where it is. Trouble is, I am not 100% sure what i'd need.
When it stopped, i didn't have any time to have a good look at it and assumed it was the water pump. Apart from the shreaded belt, I found a circular piece of plastic that looks like it goes around a pulley, but it was half melted and detatched from where it belonged.
Anyone know what this might be?
Thanks.
« Reply #4 on: 20 November 2009, 23:56:42 »
Thanks.
The aux belt tensioner is breaked, replace the pulley on it`s own ( about £30) only held on with a 15mm nut, replace the aux belt. Job done :y
Part # PULLEY,TENSIONER X25XE,Y26SE,X30XE,Y32S   9157962  :y
« Last Edit: 21 November 2009, 00:01:16 by RobG »
rustym95
« Reply #5 on: 20 November 2009, 23:56:54 »
get rac account or aa and get it picked up have to be with the car at time but they will get it home for you, cheaper than a garage to call out, get road side recovery. then you have time to fix it, :y :y
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
« Reply #6 on: 20 November 2009, 23:58:35 »
chances are its your aux belt tensioner that siezed, hence belt having meltdown.
must type faster :D
« Last Edit: 20 November 2009, 23:59:37 by billthebrickie »
froezen
  • Scarborough,UK
« Reply #7 on: 21 November 2009, 00:10:53 »
Thanks gents! This has given me food for thought and lifted my spirits.
I'm gonna grab a new tensioner and belt and see how it goes.
I was soo cheesed off originally, that I just wanted to get shut of it (it's been a bad day).
« Reply #8 on: 21 November 2009, 00:12:14 »
Just make sure you get the belt for aircon :y
The Red Baron
« Reply #9 on: 21 November 2009, 00:12:31 »
get it fixed up, im up scarborough tommoz until sunday :y
froezen
  • Scarborough,UK
« Reply #10 on: 21 November 2009, 00:16:08 »
Thanks. That'll be a 2030mm belt then?
froezen
  • Scarborough,UK
« Reply #11 on: 21 November 2009, 00:18:24 »
Hope the weathers kind for you :-)
« Reply #12 on: 21 November 2009, 00:21:40 »
IIRC, yep
hotel21
  • The Kingdom of Fife
Re: 1996 Omega 2.5 cdx - water pump probs
« Reply #13 on: 21 November 2009, 00:25:53 »
Original post modded to suit....  ;)
The Red Baron
« Reply #14 on: 21 November 2009, 00:26:21 »
looking at the forecast, i think not :(
« Last Edit: 21 November 2009, 00:27:00 by hotel21 »
