Author Topic: 2.2 Camshaft Sensor  (Read 1971 times)
Omega3
  • Hertfordshire
2.2 Camshaft Sensor
« on: 20 November 2009, 16:59:12 »
Hi everyone. Had some problems starting my 2.2 over the last few weeks. Finally got the Engine check light to stay on today and Tech 2 gives Camshaft sensor as fault.  :(
How easy is this to replace? I couldn't find a how to guide.
Can anyone point me in the right direction..  :)
Previously: Mercedes CLK 320cdi, Insignia SRi, 53 Omega 2.2CD, 02 3.2 elite, 01 Omega 2.2CD, 94 Omega 2.0 Est, Mercedes 300TE, Toyota Supra 3.0, Honda Legend Coupe, Supra 2.8i Mk2, Fiat X1/9, Lancia Trevi
Re: 2.2 Camshaft Sensor
« Reply #1 on: 20 November 2009, 17:02:46 »
aux belt off, cover off, its in between the cams, at the top.
Take the black eco strip off, and the nut at the bottom between the cams and it comes out
Omega3
  • Hertfordshire
« Reply #2 on: 20 November 2009, 17:07:56 »
Thanks for that tunnie, much appreciated.  :y
You wouldn't happen to know the correct part number...
« Reply #3 on: 20 November 2009, 17:09:42 »
not got it to hand sorry
« Reply #4 on: 20 November 2009, 17:12:30 »
90520850 £70.50 - Retail  £63.56 - Trade  £54.86 - Trade Club
All plus vodka and tonic
Omega3
  • Hertfordshire
« Reply #5 on: 20 November 2009, 17:18:27 »
Cheers for that :y I've got to do the cam cover gasket too so may try and combine the two. Is it possible to replace the sensor from above or will I still need to remove the cambelt cover and aux belt. (spanner novice)
davethediver
  • Blackburn, Lancs.
« Reply #6 on: 20 November 2009, 17:26:26 »
CAm cover has to come off along with aux belt, just do a quick drawing of it on so you know how to replace aux belt.
Easy enough to do :y
P.A. Caron de Beaumarchais
davethediver
  • Blackburn, Lancs.
« Reply #7 on: 20 November 2009, 17:27:41 »
Forgot to add make sure its a genuine sensor pattern ones are s**t  :)
« Reply #8 on: 20 November 2009, 17:58:34 »
Cambelt cover has to come off, cam cover can stay where it is. But its a good idea to combine to two, check out my guide for the 2.2  :y
davethediver
  • Blackburn, Lancs.
« Reply #9 on: 20 November 2009, 18:23:28 »
Sorry didn't come out right my last post should have read Cambelt cover has to come off ::).
As for the gaskets try this http://www.omegaowners.com/forum/YaBB.pl?num=1225024176
 :y :y
Omega3
  • Hertfordshire
« Reply #10 on: 21 November 2009, 12:23:50 »
Hi everyone. Had some problems starting my 2.2 over the last few weeks. Finally got the Engine check light to stay on today and Tech 2 gives Camshaft sensor as fault:(
Thanks for all the great info everyone.
Just a further thought though. After reading a few posts on hear about the same symptoms of engine turning over but not starting, most seem to suggest crankshaft sensor and say that may give false reading of camshaft sensor. Should I be looking for any other confirmation before I proceed?  :-/ Advice appreciated thanks.
Welung666
« Reply #11 on: 21 November 2009, 12:29:29 »
Camshaft sensor on the 4 pot and crankshaft sensor on the V6.
« Reply #12 on: 21 November 2009, 12:40:21 »
What he says ^^
One the 4 pots, cam sensors fail, crank sensors rarely fail.
V6, crank sensors always go, Cam sensors never fail
 ;D
Omega3
  • Hertfordshire
« Reply #13 on: 21 November 2009, 12:47:12 »
Cheers Guys.  :y Thank you for your advice. Mind at rest. Must get that trade card I keep meaning to apply for and get started!
