Author Topic: overherting  (Read 2046 times)
fred117
overherting
« on: 22 November 2009, 16:17:10 »
i have change main parts but car get hot on short runs but ok onlong ones 200 gls omega 98
« Last Edit: 22 November 2009, 16:19:04 by fred117 »
Neil (Cardiff)
  • Cardiff
Re: overherting
« Reply #1 on: 22 November 2009, 16:23:49 »
Maybe head gasket starting to fail. Is the car loosing water at all?
fred117
Re: overherting
« Reply #2 on: 22 November 2009, 16:28:25 »
on she not head bee change heater switch change and the state change
Welung666
Re: overherting
« Reply #3 on: 22 November 2009, 16:30:36 »
When was the waterpump last changed?
fred117
Re: overherting
« Reply #4 on: 22 November 2009, 16:31:57 »
about 9 month new one put on
Welung666
Re: overherting
« Reply #5 on: 22 November 2009, 16:33:39 »
Is the coolant clean?
Does it smell of anything other than coolant?
When it's overheating are the radiator hoses hard as if pressurised or as normal and easily squeezed?
fred117
Re: overherting
« Reply #6 on: 22 November 2009, 16:37:24 »
yes it clean and dose not smell and pipes are softbut not to soft
Welung666
Re: overherting
« Reply #7 on: 22 November 2009, 16:38:51 »
Ok then, next.....
If stationary and it starts to get hot does the fan kick in... low speed first then a higher speed as it gets close to the 100 on the temp gauge?
fred117
Re: overherting
« Reply #8 on: 22 November 2009, 16:41:11 »
fan kicks in 95/110 but dose not sped up on revs
Welung666
Re: overherting
« Reply #9 on: 22 November 2009, 16:47:01 »
It won't, it'll come on slow speed then high speed as the temp gets close to 100°. Are the top and bottom radiator hoses both hot?
fred117
Re: overherting
« Reply #10 on: 22 November 2009, 16:51:55 »
no just top bottem warm but when fan comes on temp goes write up then goes back down to 95
Welung666
Re: overherting
« Reply #11 on: 22 November 2009, 16:57:59 »
Blocked rad then..... Back flush it a few times.
Take both hoses off and run a hose in one till it runs clear out of the other, swop over and do it the other way and repeat until the water is clear all the time. Reconnect the hoses, refill the system and try it again ;) :y
fred117
Re: overherting
« Reply #12 on: 22 November 2009, 17:01:00 »
done that but on joy got wers  not better
Re: overherting
« Reply #13 on: 22 November 2009, 17:03:23 »
If it got worse, that suggests the rad is at fault, and it just moved the blockage along.
Take the rad out, put it on a level surface and fill with boiling water, then feel by hand on the rad for any 'cool' spots
fred117
Re: overherting
« Reply #14 on: 22 November 2009, 17:06:13 »
i will try that thanks  fred
