Author Topic: auto box help  (Read 1440 times)
dubford
  • berkshire
auto box help
« on: 22 November 2009, 01:03:22 »
hi guys
had a prob with my omega for a wile when i boot it it leaks oil from the join between the box and the engine. so with changing the rocker cover gaskets thinking it was that im still no better off . But ..... a few days ago the car started to "clutch slip"( yes i know a auto doesnt have a clutch) to the best of my discription. Now its got to the point where it doesnt even drive it just revs up and crals(2mph) . ive sort of come to the conclusion that my rear main oil seal has gone as of the first prob.... the oil .......but.....
do you guys think the oil has oppsed the talk converter
any ideas or help on  this would be great and pls tell me if im completly barking up the wrong tree!!!
Neil (Cardiff)
  • Cardiff
Re: auto box help
« Reply #1 on: 22 November 2009, 01:11:09 »
Is it leaking engine oil or transmission fluid?
dubford
  • berkshire
Re: auto box help
« Reply #2 on: 22 November 2009, 02:02:03 »
engine oil thats what made me think rear main seal
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: auto box help
« Reply #3 on: 22 November 2009, 05:13:45 »
have you checked the engine speed sensor for the gear box ecu, :y
Re: auto box help
« Reply #4 on: 22 November 2009, 14:41:28 »
Sure its engine oil?  I'd check atf level first in autobox as symptoms are those of low atf!   Remove rubber plug at bottom of gearbox bell housing and feel with your finger for atf fluid here - it should be dry!If not your leak could be due to nackered front seal on g/box input shaft - remove torque convertor (once gearbox out!!!) to see - three bolts hold it in.
dubford
  • berkshire
Re: auto box help
« Reply #5 on: 24 November 2009, 01:35:49 »
1) how do i check the engine speed sensor?
2)the puddle underneeth was defo engine oil b4 the box buggered up
thanks for your input lads i do apreciate it
just one more thing ..... this site doesnt send out email notifications . do you know if you have to turn it on or set it up?
