Author Topic: Another Miss problem  (Read 1322 times)
david036
  • Lancashire
« on: 21 November 2009, 23:10:14 »
Had a look through various miss fire posts but can't seem to see one that similar to my problem so her goes:
Have a 3.0V6 which under normal conditions drives as it should, but every so often she will start missing, seems to happen under load, thought at 1st it could be the auto box but has even had its miss when in neutral and just revving it.  When it clears...she then  goes
Any ideas?
TOYOTA AYGO, CITROEN C1 ENGINE PARTS FOR SALE.  ENGINES HAVE LESS THAN 10MILES ON THEM.  CATS FOR SALE AS WELL.  HUGE SAVINGS ON DEALER PRICES
Re: Another Miss problem
« Reply #1 on: 21 November 2009, 23:12:39 »
Dis pack or crank sensor.Any oil in the plug wells ? Do the paperclip test and post any fault codes. :y
david036
  • Lancashire
« Reply #2 on: 21 November 2009, 23:21:24 »
Will the paper clip test work?
Is there a correct way to do it on this engine?
serek
  • huntingdon
    • 3.2 mv6
« Reply #3 on: 21 November 2009, 23:33:06 »
have look here
http://www.omegaowners.com/forum/YaBB.pl?num=1189022687 :y
« Reply #4 on: 21 November 2009, 23:43:15 »
Any ideas?
Sounds like a plug or lead breaking down
« Reply #5 on: 22 November 2009, 00:30:54 »
Yes. If no codes, plugs first, cheapest and will show oil in the plug wells in the process, then leads then dis pac in order of pita to change.
david036
  • Lancashire
« Reply #6 on: 22 November 2009, 09:02:30 »
Will check the codes and plugs later on today.  What would it mean if there is oil in the plug well?
david036
  • Lancashire
« Reply #7 on: 24 November 2009, 21:59:24 »
Finally got round to checking the plugs....Well 3 of them!!  These are certanly past there best.
But they are full of oil?  I have seen this mentioned before what 's the cause of this?
Also weather its related or not I am getting engine light on as well, on intermitantly could this just be down to the miss fire?
Nickbat
« Reply #8 on: 24 November 2009, 22:04:25 »
Cam gaskets gone.
This tells you how to replace them. Not a difficult DIY job.  :y
http://www.omegaowners.com/forum/YaBB.pl?num=1152564281
Page created in 0.07 seconds with 16 queries.
