Author Topic: ICV issue?  (Read 1260 times)
NewarkTerry
  • NG23
ICV issue?
« on: 24 November 2009, 20:49:34 »
Hi all...re-posting a message that I posted in the Newbie area...
my 2.0 GLS auto (T reg)is idling too fast and the revs rise and fall when I put it in park. From what I can gather it seems the ICV may be at fault? Anyone know any decent mechanics in the Notts / Lincs area that could sort it out for me, given my mechanical ineptitude.....?
TIA
Terry
Matchless
  • Nottingham
    • A white van
Re: ICV issue?
« Reply #1 on: 24 November 2009, 22:58:07 »
Classic symptoms of a dirty idle control valve, probably due to blocked or clogged breathers. Easy job to do yourself, just get a replacement IACV gasket from Vx first.
NewarkTerry
  • NG23
Re: ICV issue?
« Reply #2 on: 25 November 2009, 19:17:50 »
Thanks Matchless
I think you have seriously over-estimated my abilities there!  :)
So...no-one recommended? :(
davethediver
  • Blackburn, Lancs.
Re: ICV issue?
« Reply #3 on: 25 November 2009, 23:57:30 »
If you post up were your from maybe a more skilled local member that could help update your profile.
Im guessing its got a NG post code though ;) :y
P.A. Caron de Beaumarchais
davethediver
  • Blackburn, Lancs.
Re: ICV issue?
« Reply #4 on: 26 November 2009, 00:02:18 »
http://www.omegaowners.com/forum/YaBB.pl?num=1194007453
Try the above you may surprise yourself with your abilitys and check out other guides in the how too's sections  :) :)
NewarkTerry
  • NG23
Re: ICV issue?
« Reply #5 on: 26 November 2009, 05:40:15 »
Thanks all - profile duly updated. It is an NG23 postcode....how did you guess?   :y
I have a day off work on Monday - I may well lift the bonnet and have a look then. I'd still rather pay someone who knew what they were doing though!
