Author Topic: No Heat  (Read 1227 times)
No Heat
« on: 26 November 2009, 14:16:01 »
New HBV fitted, system flushed, no air locks. Can`t get any heat just freezing cold air.Matrix pipes are cold. If I leave engine idling for half hour with climate switched off the temp gauge will only rise to 80 deg max.
 Is it the thermostat and if so is it main dealer only :question
« Last Edit: 26 November 2009, 14:19:24 by RobG »
Welung666
Re: No Heat
« Reply #1 on: 26 November 2009, 14:23:10 »
Are the main radiator hoses warm before the temp gauge moves? If so then the thermostat is stuck open. Any (decent) motor factors can supply them :y
Re: No Heat
« Reply #2 on: 26 November 2009, 14:28:59 »
Yes Lee, boiling hot. So it looks like the stat then :question
EPC shows stat + housing. Do I need both. :-/
« Last Edit: 26 November 2009, 14:33:06 by RobG »
Re: No Heat
« Reply #3 on: 26 November 2009, 14:49:22 »
yes but, they are only about 25 quid and Halfords normaly stock them to.
Re: No Heat
« Reply #4 on: 26 November 2009, 14:52:00 »
Cheers Mark :y :y
£52 from stealers :o :o
« Last Edit: 26 November 2009, 14:53:46 by RobG »
Re: No Heat
« Reply #5 on: 26 November 2009, 15:00:02 »
I have to say though, no heat would not be the stat!
I assume the pipes to the bypass valve are connected the right way round
Re: No Heat
« Reply #6 on: 26 November 2009, 15:33:44 »
Yes. Just took it for a quiick blast, cold air, then warm,then cold, and that`s where it stays :-/
« Last Edit: 26 November 2009, 15:35:14 by RobG »
Re: No Heat
« Reply #7 on: 26 November 2009, 15:36:23 »
What happens if you set the climate to max chill and aircon on?
Re: No Heat
« Reply #8 on: 26 November 2009, 15:39:20 »
Absolutely bl**dy freezing!!!!!!!!!!
