Author Topic: Alternator refurb  (Read 2956 times)
fudy
  • manchester
Alternator refurb
« on: 15 November 2009, 01:49:27 »
Im struggling to find the parts to recon my alternator, ive found the bushes http://cgi.ebay.co.uk/12VOLT-BOSCH-INTERNAL-FAN-ALT-REGULATOR-REF-46402_W0QQitemZ310145262733QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item483619248d
and the 6202 2RS 15 x 35 x11 mm bearing http://cgi.ebay.co.uk/62022RS-Sealed-Ball-Bearing-6202-2RS-15-x-35-x11-mm_W0QQitemZ320438985696QQcmdZViewItemQQptZLH_DefaultDomain_3?hash=item4a9ba6e3e0 simplybearings has this also..
its the 62032RS - 15-42-13 i cannot find it anywhere! anyone know of a supplier? tia
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: Alternator refurb
« Reply #1 on: 15 November 2009, 01:59:33 »
there is a person in yellow pages near you he dose them, did her's for £45 changed every thing then and there, i will see what his name was but he from your area. :y
fudy
  • manchester
« Reply #3 on: 15 November 2009, 13:26:09 »
tnx m8 but im gonna have a go at it myself, i could not find them on Simply Bearings for the life of me :-[ nice one Marks!!
« Reply #4 on: 15 November 2009, 13:50:16 »
Its real easy to do.....not rocket science
fudy
  • manchester
« Reply #5 on: 26 November 2009, 02:20:47 »
62022RSH is the wrong bearing for the alternator on mine, i was lucky that a mate had a draw full of assorted bearings and even more lucky one fitted! my front bearing was grinding bad and the rear had worn down the shaft by over a mil, so that the bearing needed a shim to hold it in place
here's a pic of my alternator
i read the post about the omega from spain with diffrent bearings and im wondering if they fitted different alternators to a few cars and thats whats causing the confusion??
it took 20mins to remove it(for the second time we ran out of light first time round) and 3 hours plus a call to elite pete to replace the bearings!! ended up putting the car back together in the dark! again!  she sounds alot better now the constant grinding noise has gone!!
fudy
  • manchester
« Reply #6 on: 26 November 2009, 14:34:14 »
on the way to work this morning the display had quite a bad flicker, im gonna have to check the earths and test the voltage coming from the alternator! It would be a gutter if i had tol replace it after all the work replacing the bushes and brushes.
« Reply #7 on: 26 November 2009, 14:40:54 »
Flicker is normaly down to the spring contact that touches onto the brush/reg pack
fudy
  • manchester
« Reply #8 on: 26 November 2009, 14:47:00 »
i might just give it a few hunderd miles cos that was replaced as well! It was a pattern part with no curve on the bottom of the carbon sticks!
« Reply #9 on: 26 November 2009, 14:48:19 »
Well the brushes should form to the slip rings quite quickly.
Its the metal tag that is on the alternator that tends to need cleaning adn bending, not the plate on the reg pack.
fudy
  • manchester
« Reply #10 on: 26 November 2009, 14:51:14 »
ouch, it sounds like it might have to come off again!
« Last Edit: 26 November 2009, 14:52:49 by fudy »
« Reply #11 on: 26 November 2009, 15:00:55 »
It only takes 40 mins to wip it off and re-fit....
« Reply #12 on: 26 November 2009, 15:38:11 »
Might be an idea to put a blob  of solder between `em
fudy
  • manchester
« Reply #13 on: 26 November 2009, 16:10:20 »
im not sure where your on about is it on the back of the casing or under the black plastic cover? Im not off work again till monday so if its still playing up then i will take it back off!
« Reply #14 on: 26 November 2009, 16:20:49 »
Third pic you can see the two culprits. http://www.omegaowners.com/forum/YaBB.pl?num=1153772945 :y
Page created in 0.021 seconds with 16 queries.
