Author Topic: CAT Removal  (Read 1505 times)
capoMV6
CAT Removal
« on: 27 November 2009, 00:17:45 »
Hi guys,
What happens if I remove the CATS off my 3.0 MV6 and replace them with straight pipes? Will I lose power/torque? Is there anything I should watch out for? Appreciate your advises. Thanks.
« Last Edit: 27 November 2009, 00:18:22 by capoMV6 »
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
Re: CAT Removal
« Reply #1 on: 27 November 2009, 00:22:29 »
Not sure on gain or loss, but you may have problems at MOT time if you don't refit the cats.
capoMV6
Re: CAT Removal
« Reply #2 on: 27 November 2009, 01:54:08 »
Thanks for the concern mate. There is no MOT test here in the Philippines. Cheers.
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Re: CAT Removal
« Reply #3 on: 27 November 2009, 07:22:56 »
you lucky lucky bars**d      :D :D :) :) :)
damage consultant
  • falkirk (sunny scotland)
Re: CAT Removal
« Reply #4 on: 27 November 2009, 07:45:36 »
you might need to get the engine re-tuned best to ask the boy.
« Last Edit: 27 November 2009, 07:46:01 by senny »
djac
  • West Sussex
    • 2001/Y Omega 3.2 Elite
Re: CAT Removal
« Reply #5 on: 27 November 2009, 10:38:55 »
Some years back I had a Magnex s/s system with cat replacment pipe fitted to a Cavalier GSi. No re-tune was needed, the power improvement was noticeable but not huge.
mathewst
  • Split, Croatia
    • v40
Re: CAT Removal
« Reply #6 on: 27 November 2009, 10:41:37 »
Guys what do you think by engine retuning???
And why would that be needed if replacement cat was used?
djac
  • West Sussex
Re: CAT Removal
« Reply #7 on: 27 November 2009, 11:03:59 »
Replacing the cat with a straight-through pipe alters the flow through the exhaust.
I would have thought that the MAF and lambda sensors would be able to correct for that though?
There is not an awful lot of tuning you can do apart from free-flow air filter (or no air filter  :) ) ?
