Author Topic: Arse! MOT Failed.  (Read 3795 times)
toller
  • Mirfield, West Yorkshire
Arse! MOT Failed.
« on: 25 November 2009, 18:19:43 »
Took it for it's MOT today and it failed on two fairly piddly items.  First being the handbrake is binding slightly on one wheel (at least thats a free and easy fix) and second they said the O/S headlight lens is degraded to a point it's affecting the beam image, also got an advisory for the same thing on the N/S lens.  Not too bad but I really was hoping to have it back on the road today, all this motorcycling everywhere in hurricane force winds and torrential rain is starting to wear me down.
I now need to source an O/S headlight as i'm presuming it's a sealed unit and you can't just replace the lens.  Only planning on changing the failed light at the mo as funds are a bit tight and it's crimbo a month from today  :'(
At least it's not as piddly a fail as last year when they rejected it because a clip was missing from one of the brake flexi hoses - I was rather furious then :)
sneakypenguin
  • Birmingham
  • Xbox gamertag MagicGinjaninja
    • 07 Volvo V70 T5
Re: Arse! MOT Failed.
« Reply #1 on: 25 November 2009, 18:20:59 »
bad luck mate, but as you say, at least they're not too serious or expensive to fix
07 Volvo V70 T5 SE ex police
« Reply #2 on: 25 November 2009, 18:24:53 »
So, service the handbrake properly (as per the guide) and strip the headlights and clean them up.
Zero cost
toller
« Reply #3 on: 25 November 2009, 18:28:02 »
Handbrake is easy enough but what would you recommend for the headlights?   Am I looking at a tube of rubbing compound and lots of elbow grease or this there an easier way.
Cookie Monster
  • Andover Hampshire
    • 2000 W reg 2.5 v6 CD auto
« Reply #4 on: 25 November 2009, 18:29:25 »
Maybe i`m being a bit of an old woman or prudish but... i know it must be frustrating to say the least but is the f ...ing etc really needed on here ?
I can swear with the best of them but everything has its place.. sorry if people think i`m being too prudish its just my feelings
« Reply #5 on: 25 November 2009, 18:31:42 »
1200 wet and dry (wet) followed by a good cutting compound to finish.
I assume they looked clouded
toller
« Reply #6 on: 25 November 2009, 18:33:58 »
The one he failed it on definately looks clouded and is ever so slightly yellow,  the other looks a little hazy but is still fairly clear and not yellow.
Looks like i'll be giving my arms a workout this weekend.
goonv6
« Reply #7 on: 25 November 2009, 18:38:13 »
What he said! :y I used to do these on fiat coupe headlights. What's faded in usually a laquer. I went for 1200 grit to 1500 grit, coarse compound and then fine compound (Like G3 and G6) they'll come out like new.
Ian_D
  • York
« Reply #8 on: 26 November 2009, 00:33:35 »
Guess you cant get the car to York? Would offer to buff them up for you! Would be like new in 20/30 mins!
[size=12]
toller
« Reply #9 on: 26 November 2009, 07:17:26 »
Unfortunatley not, it's out of MOT so sods law says i'd go past about 50 ANPR's if I as much as took it to the end of my road.
Out of interest, would it be feasible for me to remove the lights in order to polish them on a very soft buffing wheel stuck on a lathe at work,  only ever polished metal before, not plastic and don't want to make them any worse than they already are.
« Reply #10 on: 26 November 2009, 08:53:03 »
I might take you up on that offer if we manage to swing by... Mine are a little cloudy ::) ::)
  • Auckland
    • Mazda MPV
« Reply #11 on: 26 November 2009, 10:53:24 »
Has anyone tried doing this?
I would be worried about overheating the plastic. Presumably if you keep it moving it shouldn't be a problem?
toller
« Reply #12 on: 26 November 2009, 13:05:41 »
I've had a go on some bits of scrap plastic today and the results look promising.  You have to keep moving it around and use a very very soft mop on a fairly low speed but it did take out the scratches i put in with some 80 grit sandpaper.
I reckon with the addition of some fine wet and dry they should come up quite good, i'll be bringing my headlights into work tomorrow to have a proper go.
Radiomarko
  • Sunny Devon
« Reply #13 on: 26 November 2009, 16:27:31 »
There are a few threads about this. My lenses which are plastic were very yellowed and scratched, MOT was due so I used "Greygate plastic polish" and 1 hour of elbow grease, worked a treat, MOT = sailed through.
Buy on FleaBay or probably the suggested rubbing compound will do the same job. I did not remove the units only masked off the nearby paintwork.
I hate seagulls.
Goonybird
  • Northampton
  • Shouldn't have gone to Specsavers
« Reply #14 on: 26 November 2009, 18:23:17 »
Try T-cut. It is excellent as a plastic polish although you do need a bit of elbow grease.
Have owned: Opel Manta A 1900 Auto Berlinetta, Opel Manta B 2.0 Auto Berlinetta, Vx Royale Coupe 2.8 Auto, various non Vx, Skoda Superb 130tdi currently Omega 2.5CDX - now Octavia vRS WRC
