Author Topic: Front fans at full chat  (Read 1150 times)
« on: 27 November 2009, 15:32:47 »
On my 2000 2.5 V6 facelift, When you switch the climate on, the fan(s) at the front seem to race at full speed - even when started from cold.
I don't think this is normal - any particular cause, such as iffy temp sensor?
Re: Front fans at full chat
« Reply #1 on: 27 November 2009, 15:37:55 »
Are they both running flat out? Could be that one is siezed because they run in series.
Failing that, would have to have a look at the schematic but could be a temp / pressure switch.
« Reply #2 on: 27 November 2009, 15:42:56 »
Yep, they are going hell for leather, even when engine stone cold.... sounds like an aeroplane  :D
« Reply #3 on: 27 November 2009, 15:44:02 »
And with the aircon off?
« Reply #4 on: 27 November 2009, 15:53:23 »
With the climate off (or on "eco") they don't operate...
« Reply #5 on: 27 November 2009, 15:56:02 »
Hmmm...so they are working as they should...just sounds like the slower speed might not be working
« Reply #6 on: 27 November 2009, 15:59:15 »
how is that corrected? :y
Pete Elite
  • Uxbridge, Middlesex
« Reply #7 on: 27 November 2009, 22:44:02 »
To stop them from coming on you could pop the fuse/s out until you sort the problem so that the engine will warm up normally :).
Page created in 0.026 seconds with 16 queries.
