Author Topic: Omega 2.5 td ignition problem  (Read 1802 times)
roki
« on: 28 November 2009, 13:03:19 »
Hi,
 My 2.5(BMW) TD Omega wont start engine. Seams that computer dont realese power to fuel pump and to Boosh heaters?
Enyone please help :-/
damage consultant
  • falkirk (sunny scotland)
Re: Omega 2.5 td ignition problem
« Reply #1 on: 28 November 2009, 13:47:16 »
is the glow plug and managment lights on when you turn on the ignition :question
does the engine turn over but won't fire :question
if these two are not on its a bad earth either to engine or ecu or both.
Had a problem yesterday with my tractor not starting.
when turned on ignition no glow plugs and no managment light but engine turned over.
FAULT bad earth between engine and batt and bad earth to ecu attached jump leeds and he presto all working again.
put new 10 mm copper earth direct from batt to block and new 6mm cable to ecu problem solved.
also codes 19 34 64  have now been reset car runs like a dream now
« Last Edit: 28 November 2009, 13:52:04 by senny »
roki
« Reply #2 on: 28 November 2009, 13:50:48 »
All lights are ON, just wont let signal to the pump and heaters, and there is no comunication whit menager device.
damage consultant
« Reply #3 on: 28 November 2009, 13:59:35 »
do you know how to do the paper clip test.
if not there is a post on how to do it in the maintanance posts
heres the fault codes.
14      Coolant Temperature Voltage Low
15      Coolant Temperature Voltage High
16      Fuel Temperature Voltage Low
17      Fuel Temperature Voltage High
19      Incorrect RPM Signal
21      Accelerator Position Sensor (APS) Signal Voltage High
23      Accelerator Position Sensor Not In Idle Range
24      Vehicle Speed Sensor Incorrect Signal
31      No Engine RPM Signal
34      Injector Timing Out Of Range
37      Incorrect Brake Switch Signal
39      Anti Theft Injection Lock Active
41      Boost Pressure Voltage Low
42      Boost Pressure Voltage High
43      Invalid Boost Pressure
44      Incorrect Boost Pressure
48      Battery Voltage Low
49      Glow Device General Error
54      Fuelcutoff Solenoid Test Incorrect Or Short To Ground
55      Replace ECU
61      Fuel Injection Quantity Control Circuit Incorrect Signal
64      Fuel Quantity Control Out of Range
65      Electronic Control Unit (ECU) Box Temperature High
81      Sensor Injection Start Short Or Open Circuit
82      Sensor Injector Start Incorrect RPM-Signal
83      Immobiliser No or Wrong Coding
84      Immobiliser No Signal
85      Immobiliser Wrong Signal
87      Air Mass Flow Sensor Voltage High
88      Air Mass Flow Sensor Voltage High
89      Mass Air Flow Sensor Range
91      Cruise Control Device Volt Low
92      Cruise Control Device Circuit Open Or Voltage High
95      Output Amplifier Defect
96      Exhaust Gas Recirculation (EGR) Valve Out Of Range
97      Wrong Fuelpump Adjustment
roki
« Reply #4 on: 28 November 2009, 14:31:36 »
Cant do a paper clip test?!!?
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #5 on: 28 November 2009, 14:50:52 »
Take a look in Maintenance Guides section.
Some 2.5TDs can be paperclipped, some can't. You may be one of the lucky ones!
« Last Edit: 28 November 2009, 14:51:10 by Reliance505 »
roki
« Reply #6 on: 28 November 2009, 14:57:42 »
Im lucky one, thx!
