Author Topic: Crank sensor on its way out?  (Read 2052 times)
Brick Tamland
  • Dublin
  • Good one!
    • '98 2.5 Manual
« on: 29 November 2009, 14:18:22 »
Got a phone call from the old man last night, he said his 2.5 was revving on its own up as far as 5000rpm but went away after a while. Havent had a chance to look at it myself (not in this wheather anyway). Is it early signs of a crank sensor?
Its a 1998 gls and there's 97k on the clock and AFAIK it still has its original sensor so that must be a record ::)
« Last Edit: 29 November 2009, 14:18:42 by Brick_Tamland »
Saving for one! All donations welcome, ask for details.
  • Auckland
    • Mazda MPV
Re: Crank sensor on its way out?
« Reply #1 on: 29 November 2009, 14:28:19 »
Petrol or diseasal?
The classic cause of diesels 'running away' is oil carry over from a blown turbo seal. :o :o
« Last Edit: 29 November 2009, 14:30:17 by andyh »
Brick Tamland
  • Dublin
  • Good one!
    • '98 2.5 Manual
« Reply #2 on: 29 November 2009, 14:32:15 »
Petrol or diseasal?
Nope, it doesn't have a moustache and its not called Brian ::)
« Last Edit: 29 November 2009, 14:32:34 by Brick_Tamland »
  • Auckland
    • Mazda MPV
« Reply #3 on: 29 November 2009, 14:46:01 »
AFAIK the crank sensor only ever causes a lack of go not too much.................
I would start by cleaning the idle control valve and breathers.
Brick Tamland
  • Dublin
  • Good one!
    • '98 2.5 Manual
« Reply #4 on: 29 November 2009, 14:51:33 »
Will do :y If it clears up that is :-/
« Reply #5 on: 29 November 2009, 14:52:34 »
No, Crank sensor failing symptons are the engine dieing, not restarting. then 10 mins later start ok.
I would be checking / cleaning the throttle body / butterflys
« Last Edit: 29 November 2009, 14:53:12 by tunnie »
Page created in 0.024 seconds with 20 queries.
