Author Topic: clicking/rattle in steering  (Read 3503 times)
Cookie Monster
  • Andover Hampshire
    • 2000 W reg 2.5 v6 CD auto
« on: 22 November 2009, 14:14:42 »
Hi all... seem to have developed a sort of clicking and sticking in the steering.. to be honest it sounds bit like a piece of plastic or something has broken off and is getting caught within the steering somewhere... i`ve taken the couling off but cant see anything so i guess the steering wheel is next... thing is i dont want a faceful of airbag by doing something wrong... so... any ideas or clues pls ?   ;)
davethediver
  • Blackburn, Lancs.
Re: clicking/rattle in steering
« Reply #1 on: 22 November 2009, 14:36:47 »
Are sure it inside the steering column and not underneath the car have a look here first http://www.omegaowners.com/forum/YaBB.pl?num=1152601938
P.A. Caron de Beaumarchais
« Reply #2 on: 22 November 2009, 15:37:29 »
Cookie Monster
  • Andover Hampshire
« Reply #3 on: 22 November 2009, 16:06:56 »
I see where u are coming from gents but no its definitely i sound of something inside steering immediately beneath steering wheel.. i can almost count the number of bits of plastic or something making the noise   :(
« Reply #4 on: 22 November 2009, 16:45:01 »
Airbag squib?
Cookie Monster
  • Andover Hampshire
« Reply #5 on: 22 November 2009, 16:47:01 »
Crikey i hope its not the squib !!... How can i get the steering wheel off  pls .... SAFELY !
RichardH
  • Ireland
« Reply #6 on: 22 November 2009, 18:27:20 »
Definitely sounds like the squib.  I had a piece of plastic break off mine before.
It's easy in theory to remove the steering wheel, but if you don't have a puller all you can do is keep tugging at it until it pops off and hits you on the chin!
  • Auckland
    • Mazda MPV
« Reply #7 on: 22 November 2009, 18:31:49 »
Have you got a tilting steering wheel?
I had the plastic cowl off mine today and saw that the universal joint looks like a hard plastic ball with two grooves around it that the steering shafts engage with. If a foreign body found its way in there it might create similar noises.
Before disturbing the steering wheel (& squib) I would take the cowl off and have a look for loose bits
1. turn wheel 90deg left, remove plastic cap & screw.
2. turn wheel 90deg right, remove plastic cap & screw.
3. remove three screws from lower cowl and you should be able to separate the top & bottom cowls & reveal all the bits that might make a noise.
One final thought, do your indicators 'self cancel'. The indicator switch might have broken and be causing the noise.
adi191927
  • London
« Reply #8 on: 22 November 2009, 19:46:40 »
http://cgi.ebay.co.uk/Laser-Vauxhall-Steering-Wheel-Puller_W0QQitemZ360197892594QQcmdZViewItemQQptZUK_Hand_Tools_Equipment?hash=item53dd77a9f2
Puller on ebay. Steering wheel off in a jiffy, airbag squib change is simple.Haynes gives a good description. Make sure you get the correct squib.
Cookie Monster
  • Andover Hampshire
« Reply #9 on: 22 November 2009, 20:45:02 »
i had the cowl off i did get a fraction of plastic come out but its still doing it .... the indicators still cancel so dont think its that... looks like it could be sqibby trouble i guess   :-/
RichardH
  • Ireland
« Reply #10 on: 23 November 2009, 08:43:14 »
Don't worry, it's not a big job at all.  You probably wont need a new squib.  Just remove the remaining piece of plastic once you take the wheel off and that should be it.
Cookie Monster
  • Andover Hampshire
« Reply #11 on: 24 November 2009, 18:17:29 »
Thank you oh knowledgeable ones... i will get out there tomorrow hopefully and have a proper look.... been laid up with man flu ... and not getting the sympathy a man deserves from er indoors  :'(
RichardH
  • Ireland
« Reply #12 on: 24 November 2009, 21:08:17 »
Don't forget to disconnect the battery first before you go messing with the airbag.  :y
Dave Elite
  • Ellesmere Port
« Reply #13 on: 24 November 2009, 21:19:56 »
I had a problem like this, it turned out to be the trafficmaster box that had come loose and fallen down and made a rattle\clicking sound when I turned the steering wheel. Could be that?
adi191927
  • London
« Reply #14 on: 24 November 2009, 21:31:22 »
Diconnect battery within 15 seconds of turning ignition off otherwise alarm will go off. With battery disconnected leave for at least one minute before attempting to remove the airbag.
