Author Topic: Heating  (Read 1306 times)
Neil (Cardiff)
  • Cardiff
Heating
« on: 29 November 2009, 19:25:41 »
The heating seems very cold on my Omega and the floor heating doesn't work at all. I seem to just get cold air out of the windscreen vents.
Today for the first time the air got pretty warm but the temp was up to about 95 because I left the car running.
Could this simply be an airlock? Or is it likely to be more sinister? Any opinions!
Thanks
Re: Heating
« Reply #1 on: 29 November 2009, 20:18:16 »
Sounds like a vaccum fault....the heater direction and bypass valve are vaccum operated so check your under bonnet vac pipes
Neil (Cardiff)
  • Cardiff
Re: Heating
« Reply #2 on: 29 November 2009, 20:58:55 »
Ah, thank you  :y Will give it a go. I've just read the vacuum pipe guide. I've got to clean the breathers and change the coolant anyway so will all tie in together. Haven't had a dry day in weeks down here though!
Re: Heating
« Reply #3 on: 29 November 2009, 21:37:26 »
Same here!  :-?  :-?  :-?
I'm thinking of looking on eBay for plans on building an Ark!  ;)  ;)
