Author Topic: auto gearbox drain/fill plug  (Read 1208 times)
gazdon
« on: 30 November 2009, 16:36:47 »
hello pepole were is the drain and fill plugs located on the 2.0  autobox preface lift model also isit easier to fit the cambelt/kit than the vectra due to having more room to work regards gaz :)
sparkyw666.
  • aberdeen uk
  • aka mark w
Re: auto gearbox drain/fill plug
« Reply #1 on: 30 November 2009, 16:40:48 »
you only have a fill hole u need to take the sumps off the box to drain am afraid
v6 cam locking kit  member:y
« Reply #2 on: 30 November 2009, 16:40:58 »
plug is on the drivers side toward the front of the box, fluid should be level with this plug with the car on a level surface with the engine running.
Cambelt is easier, as the engine is facing the right way!
gazdon
« Reply #3 on: 30 November 2009, 16:57:04 »
thank :)you for the info
