Author Topic: Door Hinge  (Read 1400 times)
davethediver
  • Blackburn, Lancs.
Door Hinge
« on: 30 November 2009, 23:31:22 »
The door on my drivers side seems to have dropped ever so slightly can hear it catching when closing the door :(
Is it easy enough to adjust it? Or is it new hinges?
Door check straps seem fine changed them within a day of getting the mig :y
P.A. Caron de Beaumarchais
waspy
Re: Door Hinge
« Reply #1 on: 30 November 2009, 23:38:04 »
Are the rest of the panels out of line slightly with the door?
It maybe that the stricker plate needs adjustment ;)
Allways look at the easiest first :)
davethediver
  • Blackburn, Lancs.
Re: Door Hinge
« Reply #2 on: 30 November 2009, 23:50:14 »
Hadn't thought of that pete will check tomorrow, think it is the hinge though as it catches at the bottom i think. But will have a proper look in the morning :y
waspy
Re: Door Hinge
« Reply #3 on: 30 November 2009, 23:52:15 »
Welung666
Re: Door Hinge
« Reply #4 on: 01 December 2009, 07:23:35 »
Hinges aren't changeable! You can try replacing the pins (I have a few) or order oversize pins from Vx and ream out the existing holes :y Let me know if you want a couple of pins and I'll drop them in the post. :y
davethediver
  • Blackburn, Lancs.
Re: Door Hinge
« Reply #5 on: 01 December 2009, 09:34:17 »
Thanks lee appreciate that, think thats going to be the best port of call. Think im down your way this weekend and early part of next week so i@ll call round if thats ok :) :)
Welung666
Re: Door Hinge
« Reply #6 on: 01 December 2009, 14:12:51 »
Will you be in the car? If you are I'll show you the easy way to change 'em ;) :y
PM sent with my number ;)
davethediver
  • Blackburn, Lancs.
Re: Door Hinge
« Reply #7 on: 01 December 2009, 17:42:11 »
Cheers lee got your number not sure if im in car or if i'll be in works van will let you know.
Thanks again pal  :y
Welung666
Re: Door Hinge
« Reply #8 on: 01 December 2009, 20:16:27 »
Thanks again pal  :y
Cool, whichever you're in I'll show you, I have mine here ;)
