Author Topic: mayo on filler neck  (Read 2209 times)
medwaykent
mayo on filler neck
« on: 29 November 2009, 12:59:18 »
spent yesterday afternoon washing through heater matrix had car idling for long periods of time .today took car on short journey about 5 miles ..got out could smell a hint of burning oil had quick look under bonnet could/nt see any thing really ,opened up filler cap and there is the start of mayo being formed (was/nt there last week ) anything to worry about ? no oil in water but hell of alot of pressure in exspansion tank  :'(head gasket ?
Re: mayo on filler neck
« Reply #1 on: 29 November 2009, 13:03:24 »
Which engine do you have?
steverubberduck
  • Kidderminster
  • MV6 BABY!!!!!!!!!!!
« Reply #2 on: 29 November 2009, 13:52:00 »
I had a similar problem in my old mig.
I was told that migs don't like doing short journeys.
Or ticking over for long periods.
Take it for a good run maybe?
amba
  • Medway towns
    • German V6
« Reply #3 on: 29 November 2009, 15:22:09 »
If it is really thick give the filler neck a real good clean and remove as much as possible.If oil has not been changed recently good excuse to do a filter and oil change then give the car a good run at speed.
Biggest problem of oil mayo is lots of short runs which doesn,t allow oil to get up to temperature and cause it to condensate in filler neck.
Post up your location or drop me a pm as assume you are from Kent(with your username) ,so I am quite happy to give a second opinion if needed.
  • Auckland
    • Mazda MPV
« Reply #4 on: 29 November 2009, 15:52:04 »
hell of alot of pressure in exspansion tank  Cryhead gasket ?
Worst case - yes  :(
Given that you have been flushing the cooling system there could be some air still in the system (air expands more than water when it is heated) so it is worthwhile giving it a chance to work its way round the system before you assume the worst.
On the other hand, if you have been having problems with lack of heat it may have been caused by exhaust gases (from the early stages of gasket failure) causing an air lock in your heater matrix.
medwaykent
« Reply #5 on: 29 November 2009, 16:56:23 »
engine 3.0 not had car long ..guy i bought car off said he had cambelt and head gaskets done a couple of years ago he did only a few thousand a year in it .. im in tonbridge not in medway anymore but often over that way so might take you up on offer off second opinion
« Reply #6 on: 29 November 2009, 17:19:16 »
Mayo is common on every engine that does short journeys, its just more obvious on a V6 as it has an extended filler neck that traps water vapour......most other engines have this area 'cleaned' by the oil splashed off the cams
And the coolant system should be pressurised.....when its over pressurised you would know as the relief valve in the coolant expansion cap would open.
medwaykent
« Reply #7 on: 01 December 2009, 21:03:54 »
thx guys for all the helpful knowledge  :y :y :y :y :y :y :y :y :y :y :y :y :y
