Author Topic: Replacement Diss Pack fail  (Read 1411 times)
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« on: 03 December 2009, 13:56:29 »
As above failed after about 200 miles, no oil in plug seats, Any ideas what would cause this?
Update, Mig 3.0 V6
« Last Edit: 03 December 2009, 13:59:21 by zirk »
Re: Replacement Diss Pack fail
« Reply #1 on: 03 December 2009, 14:06:09 »
Brand new VX item ???  Faulty manufacturer item .. get replaced under warranty
2nd hand/ scrappy item ??  Previous history unknown .. might have been used for a while in a car with all sorts of problems....  especially leaking cam covers
zirk
  • Epping Forest
« Reply #2 on: 03 December 2009, 14:12:19 »
It was a known (to be good)replacement off another 3.0, could be it just failed, didn't want to put another on without explorering the options, if that makes sense.
« Last Edit: 03 December 2009, 14:14:20 by zirk »
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #3 on: 03 December 2009, 16:08:59 »
in what way has it failed ?
total or just missing ?
zirk
  • Epping Forest
« Reply #4 on: 03 December 2009, 16:30:49 »
Missing, sounds like one of the pots, was fine with the replaced Pack, now same fault. Probably do the whole lot again this weekend (plugs, leads, pack), was just trying to get some ideas in case it could be something else.  :y
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #5 on: 03 December 2009, 16:41:56 »
might be worth having a good luck at the 4 pins crimps in the Lt plug  :y
coil pack is basiclly 3 coils in one unit.
4 pins ........... 1 to each coil and a negative the trigger it or is it the other way round  :-/
if one of the pins has a bad conection then it will cause one of the coils too play up making the engine miss  :y
amba
  • Medway towns
    • German V6
« Reply #6 on: 03 December 2009, 16:43:53 »
How old are the plugs ?...start with the cheapest first..which is what I should have done few weeks back as had similar fault.
Bought new dispack still had problems..replaced all plugs and problem solved,and less than £15=00,so good for another 40k.
zirk
  • Epping Forest
« Reply #7 on: 03 December 2009, 17:58:47 »
Thanks for the pointers.  :y
