Author Topic: Front Wheel Wobble !!!  (Read 1199 times)
Richard A
  • Aldridge, West Midlands
« on: 02 December 2009, 21:23:24 »
Feels as if the front offside wheel nuts are loose, there not, I think the tyre is outside balance limits, 107 grams inside 97 grams. Any ideas !!
regards
Richard A
richard a
Cotty
  • Darwen,Lancashire
Re: Front Wheel Wobble !!!
« Reply #1 on: 02 December 2009, 21:36:09 »
Swap your back tyre with front or your spare if its a goodun,it'll give you a good idea if it's the tyre at fault or not!! :y
Richard A
« Reply #2 on: 03 December 2009, 19:15:41 »
I had moved wheels around with little change, put the spare on and problem has gone. The 'tyre man' is rotating the tyre around the wheel in an attempt to spread the weight or evenly. If not possible it will be a new tyre.
Many thanks
Richard A
richard a
« Reply #3 on: 03 December 2009, 20:27:47 »
Maybe try a 5 stud balancer, cone balancer not usually, or quite often, not accurate enough.
