Author Topic: spanner light  (Read 1608 times)
TaxiManDan
  • Cheltenham
spanner light
« on: 03 December 2009, 05:42:07 »
hi guys. was coming home from work just now and i booted it off the lights quite sharp and my car/spanner light has came on and has started running really slow, i cant use sports mode but its not misfiring i can rev right up still so dont think its in limp mode?????
i have no eml light, if i turn her off then back on again she runs norm for a sec then i here a thud from mayby the gearbox and then the light comes on again and she runs slow, any ideas? i am wondering if this is to do with the rattle i have from the torque converter like a ball bearing ratttle on tick over, also i dont have a gearbox message on the mid, any advice woulld be great, thanks
TaxiManDan
  • Cheltenham
Re: spanner light
« Reply #1 on: 03 December 2009, 05:48:54 »
oh yea and the cam sensor was changed last year 20k ago
Welung666
Re: spanner light
« Reply #2 on: 03 December 2009, 06:05:16 »
It's not normally the cam sensor on the V6's. Do the pedal trick on it (instructions below) and report back the codes :y
serek
  • huntingdon
    • 3.2 mv6
Re: spanner light
« Reply #3 on: 03 December 2009, 10:21:22 »
spanner light on V6 come on dash when auto box start play, start from check code :y
TaxiManDan
  • Cheltenham
Re: spanner light
« Reply #4 on: 03 December 2009, 16:27:23 »
its bringing up code P0748 (6) in auto transmision on "My Naff Code Reader"
Re: spanner light
« Reply #5 on: 03 December 2009, 16:39:37 »
Faulty oil pressure control solenoid in gearbox. May be dodgy connector P0748 or solenoid stuck off P0746
TaxiManDan
  • Cheltenham
Re: spanner light
« Reply #6 on: 03 December 2009, 16:48:27 »
does this mean i may need a new box? if not where do i start. thanks
Re: spanner light
« Reply #7 on: 03 December 2009, 16:50:58 »
If it's one of the soleniods accessibly from removing the sump, you may be lucky
If you've been hearing nasty noises from the box, this may reduce your chances though!
Richard A
  • Aldridge, West Midlands
Re: spanner light
« Reply #8 on: 03 December 2009, 19:49:26 »
Sounds as if 2-3 soleniod is 'playing up', about £80 from 'dealer' (OOF members may help). Drop both auto sumps (very smelley), take out and clean filter, refit and fill with DEXRON 3. If you want a photo of the inside of the auto box send me a PM  :y
I had the same problem 8k ago, all ok now.
regards
richard a
richard a
TaxiManDan
  • Cheltenham
Re: spanner light
« Reply #9 on: 03 December 2009, 23:33:21 »
thanks for the info guys, i have just hopped back in and drove it a few miles and all seems normal again???
TaxiManDan
  • Cheltenham
Re: spanner light
« Reply #10 on: 04 December 2009, 22:00:09 »
gearbox has died  :'( :'( :'( :'(
got a new one being fitted tomorrow  :)
hopefullly i will have some luck with this miggy now
vaux told me to fill with dexron 6 can anyone verify this?
they told me dexron 3 is no longer used?
« Last Edit: 04 December 2009, 22:01:45 by Dans.2.2-16v »
