Author Topic: Recirculating Flap not working  (Read 1858 times)
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« on: 06 December 2009, 13:14:34 »
I believe that my recirculating flap on the blower is not functioning .When I press the switch it lights up but I hear no movement.Could  it be a relay or solenoid problem.or a linkage dropped off?  Any help would be appreciated.
Ron
Tim7
  • Wiltshire
Re: Recirculating Flap not working
« Reply #1 on: 06 December 2009, 13:31:12 »
Put the same post up yesterday but had no reply, seams on mine that i have no vacuum on the blue pipe that feeds it, so may have to strip out the control pannel to check every thing is working be hind the dash.
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #2 on: 06 December 2009, 13:34:34 »
Thanks for the reply Where is the blue pipe can I find it without a strip down
Ron
Tim7
  • Wiltshire
« Reply #3 on: 06 December 2009, 13:46:17 »
I took out the glove box, the solinoid and acctuator are behind it but it seams the supply comes from behind the heater control panel, which is a center dash strip down. I had to do this some months back to replace the bulbs behind the control panel, took a while to do, got it back togeather and reilised the vacuum pipes had come off and had no heating control so had to strip it all down to put the pipes back on, was not happy.
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #4 on: 06 December 2009, 13:50:58 »
Thanks Tim Sounds like a glove box out job was that difficult
Ron
Tim7
  • Wiltshire
« Reply #5 on: 06 December 2009, 14:02:37 »
Glove box is not to difficult to get out, I dont have a passenger air bag so for me its open both doors undo 6 screws on the front then take the side vent off and there ars 3 screws holding the side, then it comes forward and out, disconecting the wires fore the light. There is a guide on the forum on how to do it with pics. :y
